delay on hardware inserts
on TDM systems i know you could reduce the DSP delays of a plugin by using the time adjuster plugin, but how does one reduce the delay when using a hardware insert on a digi 002?
Re: delay on hardware inserts
reduce hardware buffer?
but that would reduce the delay on what you hear? how would one reduce the delay to tape?
everything you hear is true you can always shift the track if it's not correctly aligned...
Hardware insert 1&2 cutting off other hardware inserts on aux tracks | Led | Windows | 4 | 12-09-2013 09:19 AM |
Delay from Inserts, How to compensate | CisumBlue | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 01-24-2010 08:47 AM |
Delay compensation with hardware inserts | d.f. | Pro Tools TDM Systems (Mac) | 18 | 03-10-2009 11:57 PM |
DELAY COMPENSATION ON INSERTS | WrekdaHouse.ar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 04-27-2005 11:22 AM |
Delay Comp on H/W Inserts | perfectsound | Pro Tools TDM Systems (Mac) | 0 | 05-07-2004 12:38 PM |
