Old 05-22-2020, 06:27 AM
Norad155 Norad155 is offline
Default Eucon 20.5 Automation Lag
New Eucon 20.5 Dock and S1 have a showstopper for me.
there's a lag before it'll write fader automation.
Roll the transport and immediately grab the fader... it takes a beat to start writing.
If you write before transport rolls it will write static for a second, then start writing.
I measured it... on this particular session it's 12.5 frames (half a second) from where the transport rolls until you can actually write automation.
PT 2019.6
Multiple restarts of computer and Eucon provide no relief.
IMDB
Old 05-22-2020, 09:56 AM
EddieJones's Avatar
Default Re: Eucon 20.5 Automation Lag
Hi, What surfaces do you have and how many tracks, VCA's etc do you have in the session ? What OS and computer version ?
Old 05-22-2020, 10:25 AM
S1/Dock (ipads, but haven's with or without)
tried each surface individually as well
OSX 10.12.6
PT 2019.6
Mac Pro (Late 2013)
64gb ram
Noticed it first in sessions with
about 300 tracks
9 vcas, but does it in all real world sessions. (tried about 15 different session built with 2 templates)
seems to be tied to the video engine(DNX pix)... if I turn it off it's a little bit better (still kinda odd...while you're hitting play... jump instead of smooth for the first 6-12 frame.) Video engine on, no automation moves for up to a second.
a fresh session with 200 mono audio tracks performed fine.
IMDB
Old 05-22-2020, 10:36 AM
EddieJones's Avatar
And to confirm this wasnt happening in a previous release of EUCON and if so what was that version ?
Old 05-22-2020, 10:42 AM
Correct. Only thing I changed was Eucon (and associated firmware updates) previous version was 20.3(whatever the latest was 3 days ago)
it's similar behavior to the bug on 20.3 where there would be a lag after changing a softkey... but that went away with a restart, and I cannot confirm if it is the EXACT same behavior.
IMDB
Old 05-22-2020, 11:48 AM
EddieJones's Avatar
For anyone that feels the need to roll back to 20.1 here's the ipa https://1drv.ms/u/s!AowqasI1coAD49BM...da4Tg?e=6kKham
This is unsupported though by Avid.
Old 05-22-2020, 12:02 PM
Thanks I'll give that shot
IMDB
Old 05-22-2020, 03:48 PM
bluesfrequency bluesfrequency is offline
PT 2019.6
Same bug I reported yesterday.
Carlos Sanches
Re-Recording Mixer
Audio Circus
Warner Bros. Animation
http://www.imdb.com/name/nm0760851/
Old 05-26-2020, 06:23 PM
upodate:
PT 2020.5/Eucon2020.5/os10.14.6 Mac Mini2018
does NOT have this problem. Works pretty smoothly. Same sessions that had the issue on the other rig.
IMDB
Old 05-27-2020, 12:29 PM
upodate:
annnnd It's back....
IMDB
2018.7 Automation choppy with Eucon controller SFXgeek Artist Series 11 03-18-2021 09:06 AM
Logic 10.4.2 breaks Eucon automation modes. robertg Artist Series 25 05-19-2019 04:59 PM
Eucon/Artist Mix Trim Automation selection HotRats_Reloded Artist Series 1 10-06-2018 05:29 AM
automation mode glitch almost fixed in Eucon 3.4 ??? yoerik Avid S1, S3, Dock and Control App 7 09-05-2016 07:15 AM
PTHD 12.1 and EuCon automation reichman Artist Series 1 07-09-2015 10:45 AM
