Go Back   Avid Pro Audio Community > Pro Mixing > System 5
Old 11-29-2012, 08:27 PM
lukesytan lukesytan is offline
Default MC Pro with Internal SSD
I've got 5 Euphonix MC Pro controlling Pyramix software. My question is not so much software, it's more hardware.
I would like to replace the internal HDD in the MC Pro with an SSD. One of the MC Pro's HDD is failing, so I'm thinking of replacing it with an SSD. We've found that the HDD, when it spins, makes quite an audible noise, probably because our MC Pros are old. So, I'm thinking of replacing it with an SSD in the hopes of reducing that noise.
Has anybody tried it before and what are the recommendations?
Thx and I look forward to any feedback.
Regards
Luke
Old 11-30-2012, 01:59 AM
klaukholm klaukholm is offline
Default Re: MC Pro with Internal SSD
I would also very much like to do the same in order to reduce the bootuptime.
Old 12-18-2012, 11:31 PM
Roll Roll is offline
The only solution is to find a IDE to Sata converter small enough to put in the mc pro
Something like that : http://www.amazon.com/gp/aw/d/B002Y2...sr=8-1&pi=SL75
Old 12-19-2012, 09:01 AM
Craig F Craig F is offline
there are PATA SSDs but they are not cheap, (limited market)
Thank you,
Craig
Old 12-19-2012, 10:20 AM
Ow you're right ! I didn't know !
But it's kinda cheap !
http://www.amazon.com/Transcend-soli...ref=pd_cp_pc_1
Old 01-03-2013, 09:42 AM
a CF to IDE might work like this http://www.meritline.com/new-dual-cf...--p-60222.aspx
CF cards should be around for some time, also should be easy enough to have a clone on hand
Thank you,
Craig
Old 01-03-2013, 11:04 AM
Nice one !!!
The only problem is that the card is in a 90 angle,'and cannot enter in the mc pro
Old 01-08-2013, 09:44 AM
extra small SATA so the SATA to PATA bridge should fit
http://www.storagereview.com/stec_s2...ssds_announced
Thank you,
Craig
Old 05-14-2013, 09:22 AM
I just found that there is a SATA connector inside the MC Pro
http://avid.force.com/pkb/articles/e...kbase&filter=0
2nd Internal HDD? dts.music 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 08-29-2008 09:05 PM
I've Never Had To Do This, Is It Internal? Bloux 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-21-2002 11:41 PM
Internal HD G-Dog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-03-2000 10:03 AM
QT from internal G4 ATA tombi Pro Tools TDM Systems (Mac) 2 06-20-2000 10:48 PM
internal hd for g4? fiddle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-02-2000 04:57 PM
