Minor problem....Can\'t access \'manual\' from session...
Not a huge deal at all, but for some reason, my ProTools Reference Guide won't open from 'Help' within a session. I can only go to the Digidesign folder, where it will open.
Anybody else have this happen, or maybe have a solution? thanks, Roy
rh music |
Re: Minor problem....Can\'t access \'manual\' from session...
What do you need the reference guide for?
You got us Roy. Don't you like us any more. [img]images/icons/grin.gif[/img] |
Ok,
Sorry just kidding. May be your path to adobe acrobat got changed or something. |
[img]images/icons/grin.gif[/img] Oh, I know you guys are here, Swap, which is so cool. But I don't want to post every little question I have (aah, you know what I mean). It's funny, but I think it's only done this since the move to XP.
Like I said, not a huge deal though. I'll leave this up just for a while to see if anybody has any ideas....... thanks, Roy
rh music |
I had that happen once, but a reboot fixed it.
Jared O'Pry |
In order to be accessed from the Pro Tools Help menu, it needs to be located in the "Release Notes & Documentation" directory, and it needs to be named exactly the same as the original:
PT Reference Guide.pdf If you download PDFs from the Technical Documents Library, they will be renamed for internet downloads and versions, such as the most recent version of the reference guide: www.digidesign.com/support/docs Pro Tools Reference Guide (10.4 MB) Version 6.0 for TDM or LE Systems on Macintosh Version 5.3.x for TDM or LE Systems on Windows or Macintosh Version 5.1.x for MIX or LE Systems on Macintosh The downloaded PDF is named: PT_6.0_Reference_Guide.pdf Rename it: PT Reference Guide.pdf and place it in the Release Notes & Documentation folder, and it should show up in the Help menu.
Administrator Avid Pro Audio Community |
Path could have changed
especially if you switched from 98 to XP. Like digi said just move the pdf's over and make sure the names are right. You probably figured that out already so I hope I am not being redundant. |
Minor problem while saving a session | lumcas | macOS | 5 | 08-07-2019 02:47 AM |
possible to access the Automation window Manual Write parameters on Procontrol ?? | vudoo | ProControl, Control|24, Command|8 | 2 | 12-12-2009 03:00 AM |
MINOR PROBLEM WITH PROTOOLS CAN SoME ONE HELP ME | KineticRdy4War | Pro Tools M-Powered (Win) | 2 | 04-19-2007 05:34 PM |
882 Studio Audio Interface (Session 8) manual | Jeff_Fry | Digidesign Hardware & Software | 2 | 01-17-2007 11:58 AM |
Pro Tools Project Card NuBus (Session 8) manual | Jeff_Fry | Digidesign Hardware & Software | 3 | 10-22-2006 05:51 AM |
