Beat Detective Quantization Issue
Hi there.
I'm currently trying to time correct drums tracks and am having a crippling issue with some imminent deadlines. Hope someone can help. My drummer did a decent job, so most of the hits aren't too far off the grid, but I'd still like to tighten things up a bit. After I've established my trigger points and separated my clips, everything is normal. My issue concerns the "Clip Conform" portion of the Beat Detective window. I proceed with 95% strength and a 4% swing and hit the button, and at first everything sounds alright. But as I continue to listen it's apparent that Beat Detective has stretched the tempo grid to the right slowly (continuously) and toward the end of the song, my tracks are off the actual grid by more than 3 beats. It's a nightmare trying to fix this because it's continually moving farther and farther out of sync. So, I'd have to move each hit individually to perfectly fix the problem. I've tried messing with the conformity strength (0%-100%), the "Exclude Within" option, the "Swing" option, as well as the note value, Start / End Bar Beat, time signature, and nothing is making a difference for the better. Not exactly sure how to trouble shoot this, any ideas? |
Re: Beat Detective Quantization Issue
First, you didn't list any system or PT version info.
So I don't know if this is your problem or not, but in my experience, most issues with BD not working properly are user error and most often due to incorrectly setting the Selection start and end points. I would double check that the triggers of all your sections (I assume you separated in sections--for me 8 bars is my average length--going higher for really simple parts and lower as complexity increases) are accurate.
Chris Neal :: South Plains College .: Program Coordinator & Asst. Professor in Sound Technology .: [email protected] .: Pro Tools Certified Instructor .: Pro Tools Expert Certified in Music |
Haha. Yeah, I guess I never got the memo on the less bars deal... It's worked until now, but I've been trying to quantize the entire 109 measure tune full of 16th note syncopation.
I'll give that a shot. Thanks. |
Tempo mapping Beat Detective or identify beat? | grateful | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-14-2012 09:13 PM |
Grid and Bar/Beat Markers scrambled and disabled after using Beat Detective!! | Robbry | Pro Tools M-Powered (Win) | 0 | 02-24-2010 02:14 PM |
beat detective multi-track issue | DavAshMusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 02-06-2010 06:48 PM |
Beat Detective Issue | FafSchimpf | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 07-04-2007 11:14 PM |
what do grid lines do after beat detective bar-beat markers | cc1 | Pro Tools TDM Systems (Mac) | 1 | 05-22-2007 09:34 AM |
