Old 06-08-2015, 10:38 AM
AINSLIE's Avatar
AINSLIE AINSLIE is offline
Default Corrupted session HELP!
So I got the error 'The document could not be opened because it was created with an older version of Pro Tools'
I'm on PT 10.3.10HD mac using HD6. Corrupt session would not open on the same system / version it was created on nor on PT11. Backups would not open back 2 hours worth. Older versions of the session open, but at time stamp 2 hours prior to final version saved the above error is reported. My CCC archive has same issue. Drive was repaired but no luck. The 2 hours lost has a lot of mix tweaks and files added during a single mix down with artist and management present - its not gonna be cool to lose this.
I have researched this topic on the DUC - I have done all suggested fixes (prefs, permission repairs etc ..)
Does anybody have tools to repair corrupted session? HELP please!
Ainslie
http://www.ainsliegrosser.com/
MacBook Pro 2019 64GB OSX 10.15.7, HDX, Sonnet Chassis, PT Ultimate 2022.9, S3, Dock, MTRX Studio
Old 06-08-2015, 10:43 AM
Michael Zull Michael Zull is offline
Default Re: Corrupted session HELP!
Try creating a new blank session and using "Import Session Data" to import all of the tracks into the new session.
Old 06-08-2015, 10:47 AM
Southsidemusic's Avatar
Thats a good sugestion, otherwise if you can upload the session to our FTP server I can have one of our tech guys see if he can repair the session. He has all the software that big companies use to repair hard drives, cellphones and retrieve data from damaged hard drives and SSD's etc.
All depends on how much value you put on the work done as I can't say how long it will take to fix, maybe one hr, maybe 12 hrs, all depends on what is wrong so let me know if you need me to see if this can be done quickly.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 06-08-2015, 10:53 AM
AINSLIE's Avatar
When i try to import it gives same error unfortunately
Old 06-08-2015, 10:57 AM
AINSLIE's Avatar
That would be cool .. I tried Disk Warrior .. its worth an effort for me. Theres no way i can remember all the changes we made. I could upload just the session file - you dont need the audio. You wanna PM me the details? Or I can email it if you wanna give me an email - I would totally appreciate the help Christopher - thanks a ton.
Old 06-08-2015, 11:03 AM
Raoul23 Raoul23 is offline
This normally works. I've had to do this 1 or 2 times
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 06-08-2015, 11:18 AM
PM'ed you the details
Try a few times to do what Raoul said and if it still screws up send me the session as Imwrote in the PM
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 06-08-2015, 11:38 AM
AINSLIE's Avatar
Hey Gents - Thanks for your suggestions. I have solved the issue. Its a weird thing i will record here for anyone who searches the topic.
I went to work on other material on this drive and others in the enclosure, and the same error message started occurring on sessions I had successfully opened prior. Also on my backup drives. I had noticed that 1 drive in my 5 bay firewire enclosure was showing an error light a couple days ago. I had ejected it intending to deal with it later. It was one of my backups. It randomly occurred to me to reseat all my external cables. So after a shutdown, reseat of the firewire cable connecting that enclosure and then restart the initial troubled session now opens.
The fact that the drives in the enclosure passed tests including Diskwarrior complete rebuild had thrown me off the track of a physical connection error. It may be a fatigued cable - I may go ahead and replace it to be sure.
Bottom line - problem solved. I hope this is the end of it! An imperfect firewire cable connection (in this case FW800) can cause this error.
Old 06-08-2015, 11:59 AM
Great to hear
Let me know if you need any help later on if it comes back or something.
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 09-15-2015, 04:14 PM
Lamboshow Lamboshow is offline
I have a very important session that has been currupted that I need help fixing
Session corrupted? Tom Case 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-09-2010 10:01 PM
Is my session corrupted? PTLExp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-12-2008 08:36 AM
My first corrupted session under 7.3HD Alιcio Costa Pro Tools TDM Systems (Mac) 16 01-14-2008 01:51 AM
Corrupted session? Richard Fairbanks Post - Surround - Video 0 05-09-2006 04:59 PM
Corrupted Session?? dither Pro Tools TDM Systems (Mac) 4 10-24-2000 10:13 AM
