Old 06-13-2017, 10:33 AM
danielchodges danielchodges is offline
Default Can't import audio in PT 12
Hi Everyone!
A couple of weeks ago, while working on assembling a record PT stopped letting me bring in outside audio files. When I click to import audio, an error message comes up. Anyone know how to fix this, or even just a way around it? It happens in all of my sessions, new and old across multiple hard drives. The error is pasted bellow.
Could not complete the Import Audio command because Assertion in "/Volumes/Development/158347/ProTools/NewFileLibs/Cfd/MacBuild/../MacOS/Cfd_ImportAudioDialogMacOS.mm", line 573.
Old 06-13-2017, 11:33 AM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Can't import audio in PT 12
Hi, You might try a repair of permissions on the drive in question.
Help Us Help You
Chris
Focusrite Liquid Saffire 56
TCE Studio Konnekt 48
PreSonus Digimax LT
Pro Tools HD 2019.6
Old 06-13-2017, 12:50 PM
1) Try working from a different drive and see what happens
2) Try trashing prefs and database/catalogs (use Pete Gates' utility)
http://www.richbreen.com
MacPro 5,1 Dual Hex, OS 10.12.6, PT 2018 HDX, Avid HD I/Os and Metric Halo ULN8, Avid C24.
Old 06-13-2017, 07:23 PM
Thanks for the replies! I tried repairing disk permissions to the drives, and that didn't seem to do it. It happens regardless of what hard drive I'm on.
So now I'll try dumping the prefs and such. Rich, can you give me any more advice on how to do this? I'm not aware of "Pete Gate's Utility".
Thank you all again for the help!
Old 06-13-2017, 07:28 PM
Southsidemusic's Avatar
Southsidemusic Southsidemusic is online now
Here you go
http://duc.avid.com/showthread.php?t...ght=Pete+gates
Best Regards
Christopher
South Side Music Group
WEBHOME
Old 06-13-2017, 07:33 PM
Oh, awesome! Thank you!
I should have searched for it first. I'm pretty lame and new to the ways of forums.
Old 06-14-2017, 07:34 AM
You are most welcome and glad to help
Best Regards
Christopher
WEBHOME
Old 06-19-2017, 09:43 AM
Hi again everyone!
I tried clearing the prefs via PG, and working off 5 different hard drives, but I'm still getting this error when I try to pull in audio files.
Any other thoughts? If I could do this session in wavelab, at this point I would just go that rout.
Here is there error again -
(Use the Copy button to copy this message to the clipboard.)
Old 06-19-2017, 10:53 AM
john1192 john1192 is offline
Hi again everyone!
may i ask the Q: what kind of Audio files are these ?? anything Exotic ?? something pro tools will not read .. system info, OS, PT version, etc ..
try this to see what is happening .. if you open a Blank Session and go to import audio dialog box - can you play the files in there before importing ?? and what format does PT say they are ??
cheers john
OS 10.12.6 for PT 11.3.2 & 12.4 & above
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.12.6 - PT 12.4 & above
lynx AES16e-SRC & Aurora 16
Artist Transport & iPad - Pro |Control - EuCon 3.7 (older Euphonix Branded MC Transport)
Old 06-19-2017, 10:58 AM
It's always a good idea to check for illegal characters in any of the filenames, or in any of the folder or drive names that are in the path to the files. I have had illegal characters cause assertion errors in the past. May not help, but worth a look.
Scott Gatteρo
Yessian
Import Video - Audio Import Option Disabled sarcanon Pro Tools 12 2 06-14-2016 05:12 PM
Does "Automatically Copy Files on Import" work with Import Audio command? leftalive Pro Tools 10 3 04-17-2013 09:35 PM
Import Session Data with out Audio import disinfor Pro Tools M-Powered (Mac) 7 11-14-2010 11:44 AM
Import Audio search window results will not import BA Studios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-25-2008 09:00 AM
Re: Import Audio or Bounce to Disk then Import filosofem 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-10-2005 03:52 PM
