  #51
Old 10-06-2015, 03:25 PM
Default Re: Pro tools 11 locked in windows 7 taskbar
Originally Posted by Shan View Post
Interesting solution. I had this "PT locked in the W7 taskbar" issue happen to me about 2 months back. I was determined to reproduce the issue so I could log a bug. A few days later it just started working normal again. I do recall now that I had some disk images mounted in a few virtual optical drives(via DAEMON Tools) at the time. Just putting this out there as my issue appeared to be similar to yours.
Shane
Interesting. I don't minimize much but I have had this before. I rarely have a disk in the drive or images mounted which makes me wonder about flash drives as well.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 3-6-18)
Intel I7 6800k
Win 10
  #52
Old 11-20-2015, 11:03 AM
dannym dannym is offline
Default Re: Minimise PT 11.2.1 then Maximise from Taskbar
Originally Posted by unkJE View Post
Here's the Windows way.... I need somebody else to explain the Mac equivalent.
Pro Tools 11.2.1 in Windows:
Before starting Pro Tools, right-click on Desktop Pro Tools icon and choose:
Pin to Taskbar
After you’ve minimised you can maximise by left-clicking the Taskbar Pro Tools icon.
Thanks, unkJE. Solve the problem for me (Win8.1/PT 12.3.0) - but I find I have to click the PT taskbar shortcut 2 or 3 times before it works.
Pro Tools 12.3.0, Molten Music Technology laptop (Clevo rebadge), Windows 8.1 Pro 64bit, dual i7-4800MQ, 16GB RAM, Focusrite Scarlett
  #53
Old 11-20-2015, 11:47 AM
Michael Zull Michael Zull is offline
Default Re: Minimize PT 11.2.1 = Game over
Originally Posted by Michael Zull View Post
Try Alt + Tab to Pro Tools. Once tabbed to Pro Tools, if nothing pops up, use the shortcut to show/hide the mixer, which I believe is Ctrl + = on Windows. Hit it a couple times times and the edit window will reappear again as well.
  #54
Old 01-03-2016, 01:56 AM
Kamilion Kamilion is offline
I have windows 10 and was having the same problem until I found the solution:
1. Open your 'Taskbar'
2. Find the 'pro tools' that you have opened (usually toward top in Windows10)
3. click on the drop-down arrow next to 'pro tools'
4. Then, right click on the 'pro tools' that is listed UNDER THE FIRST 'PRO TOOLS' THAT YOU CLICKED ON IN STEP 2 ABOVE.
5. Click on 'Maximise' and it will restore.
I haven't figured out how to set the settings so we don't have to do this extra step everytime
  #55
Old 03-06-2016, 07:53 AM
yorgo yorgo is offline
Originally Posted by Twintone View Post
I know this thread is so oooold, but I had the same issue in PT12 since yesterday!
I tired everything mentioned in all this posting , no chance to get PT back on screen.......
But the solution was so stupid and silly........... forgot to eject a CD which stuck in the CD drive..... Pro Tools tried to start a rip service in a background process and stuck.
Maybe this is helpfull for you desperate guys!
Yes This is the answer!!!! I was having the same problem and this was the answer. I too had a cd in the d drive and I removed and VOILA! problem solved!!!!!
Thank you for posting!!!!!
Pro tools 11.3, Windows 7 Premium,
Desktop i5 4670 3.4ghz 16G ram quad core
Pro Tools cannot play. Network clock is not locked. Erik Olsson Post - Surround - Video 8 02-23-2012 10:16 AM
Locked out of Pro Tools if the previous interface isn't plugged in? simoo Pro Tools 9 5 07-19-2011 02:17 PM
Taskbar after 8.0.1 GtrDude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 09-12-2009 05:07 PM
Pesky ILok Taskbar Icon Dr Beamus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-10-2004 10:52 AM
locked pencil tools dubC Pro Tools TDM Systems (Mac) 2 04-15-2003 08:43 AM
