Old 07-25-2012, 01:02 PM
HarryLegg HarryLegg is offline
Default PT 10 audiosuite plug-ins creating clips instead of files
I went through this with a tech support person for PT who was logged into my system yesterday. My workflow is to voice a script for my clients then use two different audiosuite plug-ins to give it a little EQ and dynamics control - then I double-click with the grabber tool to name the file. I then upload the file to an ftp server for client download. The problem is that even with the audiosuite plug-ins set to create a continuous file - when I go to name it - it is only a clip and there is no option to rename the actual file. The tech admitted this was apparently a glitch he had not seen before. So, now, I have to go to the audio files folder and manually rename the file in the Mac OS in order to send it to the client. And then, of course, it shows as a missing file in the PT session. I hope this can be fixed in 10.3.
Harry Legg
VO Talent/Producer
www.harrylegg.com
Old 07-25-2012, 01:46 PM
studiostuff studiostuff is offline
Default Re: PT 10 audiosuite plug-ins creating clips instead of files
You may have put PT into the Dynamic Transport mode. Command + Control + P will toggle that mode for you.
Old 07-25-2012, 02:40 PM
Thanks - just tried that - dynamic transport is not checked. It is still behaving the same.
Harry Legg
VO Talent/Producer
www.harrylegg.com
Old 07-25-2012, 04:35 PM
capt kirk capt kirk is offline
still having trouble wrapping my mind around some of these conventions with clips/regions etc...
www.kfaudio.ca
Old 07-25-2012, 06:18 PM
JC925602 JC925602 is offline
Default
Set the plug-in handle to 0. You get à clip because you have 2 seconds of audio that is hidden on each side of the clip.
Old 07-26-2012, 01:23 PM
Harry,
Just to double-check the key Audiosuite windows;
1) The selection reference window is set to: Playlist
2) Use processed output in Playlist window is enabled (Blue)
3) Processing Output mode: Create continuous file
4) Processing Input mode: Entire selection
PT10 Automation no longer creating nodes on clips Moviesound Pro Tools 10 11 10-05-2012 09:42 AM
Audiosuite render causes Bus thread error on clips with 'Bypased clip gain' asparknz Pro Tools HDX & HD Native Systems (Mac) 0 08-19-2012 04:04 PM
Editing clips without creating new clips dimebagslash Pro Tools 10 2 07-04-2012 07:24 AM
Pan L-R on multiple clips before creating Seq? Inga General Discussion 2 04-16-2012 02:08 PM
audiosuite plug ins problem ...arrrggg audiosuite hotcarl 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-23-2004 02:35 PM
