Syncing MV 8k w/ PT or vice versa
I made a thread a while back and someone let me know how, but it didn't work....since then I've tried to get help in that thread but no one will even look in it. So I am making a new one. Do I need the MV-OP-1 expansion to sync my MV-8000 with pro tools? Rigtht now I only have the 2 stock outputs. Also when I created a new midi source it doesn't show up in the menu....how can i get it to do so?
Re: Syncing MV 8k w/ PT or vice versa
NOBODY?!?!
NOBODY?!?!
what's up mookhustle.... I never checked back to see if you still needed help with this. I had assumed that since you said my post was "very informative" that it had solved all your problems. ' just stumbled across your new post. I'm not sure exactly why it still doesn't work. The only thing I can thimk of is that the first version of the mv8k's OS didn't have a slave mode for MBC, so just be sure you have the updated OS. Otherwise, the expansion doesn't have anything to do with the sync features... it's strictly audio expansion.
The last option I can think of is that you may have a corrupted midi driver for the 002. I recently had this problem. My system was fine and from one day to the next... MBC stopped working. It frustrated me for a few days untill I finally just uninstalled PT and reinstalled it. If you want to try this... be sure that you uninstall from the PT install disk as opposed to just trashing the Digidesign folder in apps. When it asks if you want to do a "clean" or a "safe" uninstall"... select clean. Your going to need your Passkey again after you reinstall. Let me know if you still have problems... you've got me curious to see what the solution is. |
I did what you said...It works now. BUT...the beat I am transfering to PT has 5 tracks (hats, bass, kick...etc) and when i recorded the first track (Hats) I soloed it on the MV and it worked great. But then I soloed the second track (Clap) I don't hear the clap and it doesn't record anything. I still hear the hats though. What am I doing wrong now?
not sure... you might have the track in PT set to the wrong input. I do that sometimes... when I bring up multiple tracks and forget that PT automatically creates the tracks with sequential inputs. Otherwise, you might have the track on the MV set to a different output than the hats. Also be sure that you are soloing and not just un-muting.
You wrote that you, "did what I said"... which thing though?... was it the OS update or the re-install that made it work? Just curious. I should remind you that I don't have an MV and it's been a long time since I was in front of one. If you want to check out some forums that are more MV specific... peep www.mvnation.com. Anyway, glad you got your sync up and running.... let me know what it was that fixed it. |
I re-installed PT...also I didn't know i was supposed to drag the cord from the mv on Pt. ( I learned that little jem on mvnation.) I'll try the input/output and see what happens.
That's what it was.....thanks for all of your help man.
Also I have to put it on "Slave Midi" not "Slave MTC". |
cool... glad I could help.
Syncing ProTools to Logic or Vice Versa using two Computers!!! | pmcmurt | Pro Tools TDM Systems (Mac) | 11 | 09-18-2009 02:09 AM |
Man to woman or vice versa | 2fly | Pro Tools TDM Systems (Mac) | 6 | 05-14-2004 06:51 PM |
L.E. TO H.D. and Vice Versa HELLLLP | Robby Hamilton | Pro Tools TDM Systems (Mac) | 0 | 03-10-2003 03:01 PM |
Syncing Digi 001 w/ Motu MTPAV & Vice Versa | Mezcaholic | MIDI | 0 | 10-23-2001 02:26 PM |
Syncing PT to 2" and vice versa... | PeeTee | Tips & Tricks | 10 | 03-17-2001 01:49 PM |
