Cannot start Pro Tools M-Powered Essential 8 in Vista Home Premium SP2
I finally got my system to recognize the M-Audio Micro and the USB Keyboard but when I start the Pro Tools I get the following message:
"Unable to locate M-Audio hardware. Make sure your hardware is connected and turned on." I found information on this site but I need the link to the exact download driver update I should install to correct this issue. Anyone help me? |
Re: Cannot start Pro Tools M-Powered Essential 8 in Vista Home Premium SP2
Are you talking about the M-Audio USB Micro audio interface included with the Pro Tools KeyStudio?
See if this M-Audio Knowledgebase article helps: Device installed successfully but control panel shows "not connected" (Vista)
Administrator Avid Pro Audio Community |
I can also be due to the fact that most pro-tool system require you have Vista Buisness or Vista Ultimate for it to work.
Personaly I much rather like working on XP. |
Well, the documentation on this site stated that there are no known issues with Vista Home Premium as well as it was never tested. I also received a reply here that the ProTools 8 does not run on Vista but this is ProTools 8 Essential Keystudio bundle and it says Vista compatible not Vista Ultimate and Business Compatible.
It seems that neither Digidesign, M-Audio nor Avid want to take any responsibility for making a product that claims right on the box and online that it is compatible with Vista. Hell, there are even driver updates for Vista Home Premium SP2 (32bit) right on the M-Audio website. Just for the sake of argument, what is needed by ProTools 8 Essential to run on Vista Ultimate is also in Vista Home Premium - thats posted all over the internet! Also, this is my favorite - The USB Keystudio 49 keyboard and M-Audio Micro both work flawlessly with my Sony Acid Music Studio 7 and its not even on their compatibility list! Anyway, at least its not a total loss but its too bad I will never get to know ProTools 8 Essential software. Thanks for the help! |
This all pertains to the ProTools Keystudio bundle
I have run PT Essentials on a laptop with Vista Home Premium SP2 without issue. I got the Vocal pack, with the Producer USB microphone.
Did you install the driver from the DVD? You have to install it separately. |
I am having the same issue when trying to launch Pro Tools M-Powered Essentials with my newly acquired USB Fast Track mkII.
I also have Reason and Record on this laptop, and I am able to select the "DX Line" or "MME Line (Fast Track) ASIO Drivers" and it works great with my bass. But I cannot launch Pro Tools at all. My error is slightly different: "Pro Tools Application Has Stopped Working" to be exact: A problem has stopped the program from working correctly, Windows will look for a solution, yada yada yada. I put my system specs in my profile but I'm on a HP dv6700 with AMD Turion x2 (2.0G) with 3GB RAM, running Windows Vista™ Home Premium (6.0, Build 6002) Service Pack 2 (6002.vistasp2_gdr.090803-2339) |
So I just uninstalled and re-installed M powered essentials 8.0.2 from the disc that came with my Fast Track USB.
I notice thast when I restart, as directed by the installer, a program called Microsoft Register service has an error before my system boots. Also, a program called "DigiMIDI" registry service (?) is prevented from running. I also get an error concering PACEregistry (?)... I would take screen grabs but this occurs before my system boots. I have a feeling it is trying to access information online, but because I am not yet booted, and have no wireless connection established, it cannot run. Is there any way to run this after I reboot??? |
Took me a minute to realize the headphones must be plugged into the mic and the only sound is from the headphones--no computer speakers involved (feedback).
hey guys IM having the same problem and wanted to see if u can help. I have a sony vaio vgn-fz260e with 2gb ram, and i bought the m audio midi keyboard n pro tools m powered essantials 8.0.2 came with it. I downloaded everthing on the installation cd n when i try to open protools my system crashes n says dat there is not enough disk space. I teird reason4 n that works fine. I have no idea wat to do totally new so plz help me out.
Using Pro Tools M-Powered Essential (8.02) with Windows 7 32 bit (home premium) | AC/DC1212 | Pro Tools SE and Essential (Win) | 2 | 12-26-2011 10:24 PM |
Using Pro Tools M-Powered Essential (8.02) with Windows 7m32 bit (home premium) | AC/DC1212 | Pro Tools SE and Essential (Win) | 0 | 06-19-2010 07:47 PM |
pro tools 8 windows vista home premium???? | bskipacoustic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-02-2010 03:01 PM |
HELP with playback clarity__ PT M-Powered 8/M-audio 2626/vista home premium 64bit | 1600Studio's | Pro Tools M-Powered (Win) | 1 | 01-19-2010 05:44 PM |
M box 2 Pro tools LE Vista Home premium ed. SHOULD I BUY? | Benjo11 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 04-29-2008 03:28 PM |
