Old 02-08-2018, 01:26 AM
Herge Herge is offline
Default Satellite Link imperatively with a Sync HD ?
Hi everyone,
I'd like to have your opinion about the Satellite Link configuration recommanded by Avid. Here is what is written in the Reference Guide :
Satellite System Requirements
The following is required for each Pro Tools HD
system on the network:
• Avid-qualified computer
• Pro Tools | HD Software
• HDX or HD Native hardware
• Pro Tools | SYNC HD
• Ethernet connection to a Local Area Network
(LAN)
All Pro Tools systems in a Satellite Link network must be resolved to a common video reference, or “house sync,” using SYNC HD.
I'm using 3 Pro tools HD 12.8.3 with an MTRX for each slave and a HD MADI with a Sync HD for the Master. An MC 3.2 is generating word clock and blackburst.
If the Pro tools Master is locked on a Video ref (with the Sync HD) and the Slaves are locked on the Word clock, both signals coming from the same generator (MC 3.2) is it still enough acurate or do I need to really lock each Pro tools to a blackburst ?
Old 02-08-2018, 01:55 AM
BScout BScout is offline
Default Re: Satellite Link imperatively with a Sync HD ?
You need both.
Wordclock has nothing to do with picture sync and Blackburst has everything to do with picture sync. Blackburst distributors are cheap... just take your generator and distribute to the rest.
This is critical only if you want to be picture perfect. If not, the wordclock will keep digital samples in sync (keeping away digital clicks/pops/snats) but has no bearing on frame edges staying together.
Satellite Link および Video Satellite 製品関連情報 Avid Audio Japan Admin Pro Tools HD, HD Native、ICONフォーラム 0 06-16-2016 03:56 AM
Satellite Link & Video Satellite Link error on Pro Tools 9 HD 9.0.3 billegates macOS 0 09-24-2013 02:28 PM
Satellite Link in HD11 will still need Sync HD nst7 Post - Surround - Video 5 05-30-2013 04:20 PM
Satellite Link built into HD - Sync HD still required? nst7 Pro Tools 10 0 04-08-2013 08:23 AM
Confused with Video Satellite LE /Satellite Link kd_special Post - Surround - Video 0 12-02-2010 08:42 AM
