Export Only Lfe Channel in 5.1 ?
Hi there,
Does anyone know how I can export only the .lfe channel when exporting a 5.1 interleaved WAV. It's probably really obvious, but I need all other channels in the 5.1 file to be mute apart from the .lfe channel. |
Re: Export Only Lfe Channel in 5.1 ?
Split the 5.1 track into mono tracks .
Then export the channels you desire . .
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~ ~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG ~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~ |
Having easy access to the discrete channels of a multichannel track would be a very much desired feature.
iMac Pro - MacOS 10.14.6 --- - Pro Tools U HDN 2019.6 - Avid HD Omni + HD I/O 8x8x8 - C|24 | S3 | Dock |
Oh well. Back in the day of pre-interleaved days, it would have been easy to pick the channel you want from the bounce. Now that after all of the bragging PT supports interleaved files it is all of a sudden a problem. Can't you guys pick the right tomato?
I don't think you understand what I'm getting at.
It's about being able to change the volume of the center channel separately on a 6 channel track. Or lowering the surrounds. Or what have you. It's a pain to do it in PT without 3rd party applications, because everything is locked down on a multichannel track, for no reason at all.
You could put a multi-mono trim plugin on the track, unlink the channels in the trim plug and mute every channel but the sub (select each channel from the pulldown button under the chain link). You could also use this to change levels of individual channels in a surround track.
---------------------------------------------------- MacOS 12.4 / Pro Tools Ultimate 2022.4 |
I am aware of work arounds, I use Spanner for it. Just saying that this should be an implemented feature.
No insult intended. Simply pointing out this option for the OP. Spanner is terrific and obviously much more versatile than a trim plugin and the surround panner. It would be great to have that functionality built in.
8 channel polyphonic export. | TVPostSound | Post - Surround - Video | 5 | 10-02-2016 12:12 PM |
Noob 4 channel export question | Neil Sherman | Pro Tools 11 | 10 | 07-15-2016 04:53 PM |
16 channel Pro Res Export from PT11 HD? | bdangler | Post - Surround - Video | 10 | 08-05-2013 02:09 AM |
Export regions/Master channel | Benjamino | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-11-2005 09:06 AM |
How to export channel settings | rokko | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-14-2005 02:14 PM |
