I can't hear track 2 as 1 is playing ????
Hello, heres my setup.....Macbook Pro 17" 2.33 Core 2 Duo 2gigs ram, Digi 003 factory, most current update for Mac OS X 10.4.11, most current update of
Protools LE, Glyph harddrive 350gb, using Line6 Vetta to record tracks 1 , 2... Ok, I recorded track 1 using my Line6 Vetta ( I used direct outs of Vetta left and right into Digi 003 audio 1 & 2 ) the tracks play back fine. Now, for track 2 using Vetta outs same as above into Digi 003s Audio 3&4...I play and can hear audio on 3&4. But when I play what I redorded on Track 1 ( audio 1&2) the audio on track 2 (audio on Digi003 2&3) cant be heard...nothing show on the meter for track two...I recorded track one is stereo, and trying to record track 2 pn stereo. What am I doing wrong? Ive searched but cant find remedy... Im trying to rehearsh/fine tune track guitar sound but cant hear anything and nothing shows on the meter.... |
Re: I can't hear track 2 as 1 is playing ????
Hello,
Are you using input only monitoring? I have a Vetta II HD hooked up over spdif and love it!
2012 Mac Mini i7 2.6Ghz, 16GB RAM, 250GB SSD, OS 10.8.4, 003R, PT10.3.4, Midi I/O and late 08 15" Macbook Pro 2.4GHz, 4GB RAM, OS 10.8.4, Mbox2, PT10.3.4 |
@ndy, thanks a bunch...That worked!!!
Thanks for your time and effort |
@andy, whats the difference in sound quality/advantage when using spdif and Vetta?Thanks again,
Proton |
Thanks again.....
The I button is HD only. You either have to use the shortcut or select it from the menu.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D --- iCON Photography |
You can use spdif to stay in the digital domain (no loss of quality) and it opens the door for the best features on the Vetta line. Re-amping and using the Vetta as an effects processor. I like re-amping and tweaking the effects/amp settings with automation. Not to mention if you want to cover your bases; you can use spdif to send a dry signal for re-amping and use the analog direct outs to capture the performance wet! They really are versatile amps.
Can't monitor/hear midi by highlighting the midi track and playing the keyboard | jgagne1 | macOS | 4 | 01-18-2015 08:42 PM |
I hear when recording, but not playing back | gtrgriff3 | Eleven Rack | 1 | 12-13-2012 01:29 PM |
cant hear sound when playing back recording | middle05macias | macOS | 4 | 08-30-2012 11:17 AM |
How can I hear what I am playing on protools? HELP?? | cocopuffz311 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 02-21-2008 05:28 AM |
How to hear MIDI when playing, not just recording? | floridajohn | Tips & Tricks | 1 | 06-16-2006 07:22 AM |
