\'Cannot allocate disk space for recording\'
PTLE5.11/Win98SE.
Flawless for the last coupla years. Audio drive 60GB, 40GB free. Regular defrags. If i want to record a stereo track, create track and arm for record. Start recording but before anything happens, get the above message. Whats going on? I can record in mono but some of the pads etc i use from Sampletank (on a second PC) have panning and movement within the stereo field which i want. Any suggestions? [img]images/icons/confused.gif[/img]
Music for the over 40's...............when? |
Re: \'Cannot allocate disk space for recording\'
First I think you need 2 HD and use one of them exclusively for audio files. Now, if you have Norton SystemWorks try to defragment your hd with speeddisk (Norton utilities. It works for me.
Thanks but i have this set with NO ALLOCATION i.e. to use whatever space is on the disc. I wonder if this is the problem?
greenroom,
You may know this, but do you have your session length set to a limited amount of time? If not, you can get that prompt you're getting. To set it, go to Setups/Operation, and set 'Open Ended record Allocation' to say, 10 minutes (or whatever your longest sessions usually last). Beyond that, the old 'check your DMA' advice is all I have to suggest. ~Roy
rh music |
Doh!!!! [img]images/icons/rolleyes.gif[/img]
"could not allocate space on disk for recording" | Jenk2k | macOS | 0 | 02-26-2012 08:40 PM |
Could Not Allocate Disk Space For Recording | ztaylor9632 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 08-30-2011 12:34 PM |
"unable to allocate disk space for recording" error | guslov | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-01-2002 08:15 AM |
"Could not allocate disk space for recording" | yonkiman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-02-2000 01:13 PM |
"Couldn't allocate disk space for recording?" | dBHEAD | Pro Tools TDM Systems (Mac) | 3 | 10-19-1999 12:41 AM |
