Old 08-04-2002, 08:41 AM
jes's Avatar
jes jes is offline
Default mBox vs. apple audio extension/ USB weirdness
hi, i've been using the mbox for about a month now, and was using it in some live shows in NY recently and i've started noticing some peculiar things.
during the shows i was running MAX/MSP or Protools with live Pluggo plug-in manipulation on a G3 Pismo 500, 1Gig RAM, ~400MB allotted to either app.
things i've noticed: sometimes when the mbox is plugged in on startup the computer crashes almost immediately, getting an address error trying to load the apple audio extension (second init i think? after the extension manager.) I don't think it matters which version of AAE it is, i tried a couple different ones, 1.5.1, and 2.0.2.
can be solved of course most times by unplugging the mbox and plugging it in after startup, but that's annoying. and it didn't happen all the time, but i did crash onstage one night and it took a bit of thinking fast to get it to reboot. took several tries between songs.
second thing i have noticed is that suddenly no usb hubs work. i have two usb ports on the computer, so mbox takes one. i have a little dr bott that had a mouse and a midi I/O, but although they are recognized as being there by the sys profiler, they aren't getting enough power to light up/throughput data. i replaced it with a powered usb hub, and same thing if hot-swapped. if i have THAT plugged in at startup, they get enough power to throughput.
is the digi usb init rerouting usb power or something? what's going on here?
http://www.jonathansegel.com
Mac Pro 5,1 3.06ghz 64GB RAM
Macbook Pro 2.8Ghz 16GB RAM
PT 2022.10
UAD-2 Apollo Quad, PCIE and Satellite
Old 08-04-2002, 07:32 PM
Default Re: mBox vs. apple audio extension/ USB weirdness
Try turning off any startup (or wake up) sounds - or ensure that the OS isn't using the MBox for audio. If the OS tries to play back a sound before the MBox is initialized - it will hang the Mac.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 08-04-2002, 10:53 PM
jes's Avatar
jes jes is offline
i do have the bitheadz mute startup chime control panel installed. but that doesn't try to play...?
but sound is set to built in all the time.
PT 2022.10
Old 08-05-2002, 01:09 AM
teddybut teddybut is offline
I have the same problem. hard bomb crash when starting up with the message "blablabla apple Audio something blablabla"
I have the same T3 hub (not the problem for me)
when I unhook all my firewire devices (OWC 80 GB hard drive or archos CD burner) this goes away.
Are you on a pismo 400 by any chance?
teddybut
also NYC
Old 08-05-2002, 01:11 AM
aha, you are on a Pismo, I re-read your post Jon. I think it's a pismo issue.
BTW are you THE Jon Segal the amazing trumpet player?
teddy "kumpel" but
Old 08-05-2002, 11:04 AM
jes's Avatar
jes jes is offline
yes it's a pismo.. 500, but hmm. pismo usb issues? haven't heard that. where can i find more info?
no not the trumpet player, the violin player (segel not segal)
PT 2022.10
Old 08-05-2002, 11:26 AM
vf124 vf124 is offline
You may want to try an extension set solely for the mbox...
A Blues Harp and PowerBook is all I need ... along with Analog Signature Pack & BlueTubes 3.0 !!
Apple PCI Extension Shawn1272 Pro Tools TDM Systems (Mac) 1 02-26-2003 12:53 AM
Apple Audio Extension and PT The Recordist Pro Tools TDM Systems (Mac) 5 02-04-2003 01:36 PM
Apple Audio Extension 1.3.3 phonetic Digidesign Hardware & Software 5 11-03-2002 05:16 AM
Apple Audio extension 1.3.3 for use with imic Landman Digidesign Hardware & Software 1 06-14-2002 04:55 AM
Apple Cinema Extension Glenn Brown Pro Tools TDM Systems (Mac) 7 01-31-2001 12:44 AM
