Old 07-26-2023, 08:32 AM
SomeOtherGuy SomeOtherGuy is offline
Default Commit Track bug
Too often Committing Instrument tracks results in either a blank (no audio) waveform, or a partial waveform, with either the first or second half missing. Redoing Commit usually fixes the problem, but this bug doesn't inspire confidence. You have to be sure you check after every Commit procedure. I also always Consolidate MIDI clips, but that doesn't prevent this from occurring.
This has been happening for years now. Would love to see this bug killed.
Pro Tools Ultimate, Avid MTRX, MOM, MacBook Pro 16 (2023) 96 GB RAM, Mac OS Ventura, Samsung SSDs
Old 07-26-2023, 10:00 AM
skylar_battles skylar_battles is offline
Default Re: Commit Track bug
Had this issue the other day. Please fix Avid :)
Old 07-26-2023, 04:37 PM
Bob L's Avatar
Bob L Bob L is offline
Originally Posted by skylar_battles View Post
<snip> Please fix Avid :)
Let's eat Grandma.
Let's eat, Grandma.
Bob
Without a song
The day would never end
Old 07-27-2023, 10:50 AM
Originally Posted by Bob L View Post
Let's eat Grandma.
Let's eat, Grandma.
Bahaha! In any case, could you use the "Commit up to this Insert" function on the last plugin? That's how I commit tracks and have never had a problem(but it may not suit your needs)
Old 04-15-2024, 04:38 AM
MLH MLH is offline
Did you find a work around or solution @SomeOtherGuy? I am having the exact same problem. (I can't commit to insert because the instrument tracks are linked to VEP via and Aux in PT)
Pro tools 2021.6.0 Big Sur
VEP 6.5.18957
Many thanks if you have any clues.
Old 04-15-2024, 07:36 AM
I don’t think they ever tried to fix this, since it still happens every once in a while. I don’t remember ever seeing it in any lists of fixes. It may be plug-in related, hard to know.
Old 04-19-2024, 09:52 PM
MLH MLH is offline
thanks for getting back to me. I found a workaround for my situation I think. I noticed most ofthe error committing was from a certain softsyth - BBC Orchestra (Full) run via VEP. I found that if I increased the preload number in the BBC player (number of samples that get preloaded into the memory) it alleviates the situation. I have to wait (up to like 5-10 minutes) to make sure all instruments are properly loaded before opening pro tools. It seemed to solve the problem but I have to be careful with an already struggling latency issues due to so much RAM being used. Its a real pain. but a workaround at least.
Track Commit workflow question (commit to new playlist?) swethington Pro Tools 5 07-21-2021 03:14 PM
Commit MIDI Track (not instrument track) Tsen Ru MIDI 3 06-08-2020 05:56 PM
Mono source track made into a stereo Commit track [SOLVED] albee1952 Pro Tools 12 9 09-21-2016 05:30 PM
Commit Track Bug metalmixer Pro Tools 12 2 04-26-2016 04:23 AM
Commit track bug LukeHoward Pro Tools 12 0 11-08-2015 10:16 PM
