Old 02-16-2023, 08:56 PM
audiogamble audiogamble is offline
Default Always having to force quit Pro Tools
Has anyone else been experiencing lately that they're always having to force quit Pro Tools on a Mac? I'm on 2022.12, with macOS 12.6.3 . M1Max MacBook Pro . I am having the exact same problem on an M1 MacBook Air.
It's usually fine if I've been working for under an hour or so. But after any extended period of having the application open, I'll need to force quit when I want to close pro tools.
It's a minor annoyance if anything, but I'm curious if anyone else is having the problem.
Old 02-16-2023, 09:13 PM
Default Re: Always having to force quit Pro Tools
If lots of others were having the problem you'd likely be hearing about it. So just troubleshoot, trash prefs, and esp. move .aaxplugin files out of their folder and then test starting with a new empty session. Repeat all the test from a newly created admin account.
Always suspect plugins, and plugins get to potentially do stuff/write to the session file when Pro Tools tries to close.
The Pro Tools log files might give some clue... ~/Library/Logs/Avid/Pro_Tools*
Are you running under Rosetta or Apple Silicon Native. If nothing else finds a problem try switching that.
Old 02-16-2023, 09:46 PM
Just to be clear, this isn’t affecting work in any way while pro tools is open. This is just a tedious little thing that happens to me on a couple of otherwise stable systems. Was mostly curious if others have noticed this.
Old 02-16-2023, 09:49 PM
its2loud its2loud is offline
Actually, this is a known issue and it’s been problematic to isolate the issue.
It seems to happen after the system has gone into screen saver, monitor sleep, or system sleep and “woken up” from those states and then trying to quit Pro Tools.
Unfortunately I don’t have any workaround for you but just know that you’re not alone.
Old 02-16-2023, 10:11 PM
What systems are you seeing this on? I have seen plugins cause the need to force quit (but not recently/not on recent Pro Tools versions). I've not seen this at all recently on Pro Tools on Mac (mostly Intel Macs) and my monitor does sleep, the system will sleep at times as well since I'm booting around between development environments and forget they are not all optimized/set up not to sleep. Are you sure it's not a plugin or corrupt session (or corrupt template?). If not that then yes likely a PITA to find.
Old 02-16-2023, 10:22 PM
As far as I know it’s been on M1 Macs and for me is new to 2022.12.
Tested with and without plugins loaded on launch of Pro Tools and usually seems to happen after waking the system from screen saver or screen sleep when Pro Tools is still running with no session open.
Old 02-16-2023, 10:35 PM
Thanks, I'm almost all using Intel Mac still so I'll butt out.
Old 02-17-2023, 04:53 AM
Ben Jenssen's Avatar
I don't know if this is of any use; but I remember this clearly from many years back, with PT10 and maybe earlier, on Mac Pro 2008. For long periods of time. I guess it had to do with combinations of OS and PT versions. Everything working fine, but PT hangs on quit, and must be force-quit.
I made a big jump from PT10 to 2020 when I got rid of the cheesegrater, and have never seen it since. I'm still on 2020.12, though.
Old 02-17-2023, 05:07 AM
No worries. Appreciate the input and suggestions.
Old 02-17-2023, 07:13 AM
Rich Breen Rich Breen is online now
Yup - Mac Studio/Ventura/2022.12 (rosetta); PT crashing pretty reliably on quit, but otherwise stable. I have not tried to troubleshoot yet as all works fine otherwise, but will in the next few weeks. If I find anything out I'll post.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Pro Tools Crashes, Keeps Running in Background After Force Quit gabriel b. Pro Tools 11 2 01-07-2018 12:58 PM
Pro Tools refuses to quit. Have to force quit. SD2 Pro Tools 10 13 01-23-2014 08:21 AM
The following incident with Altiverb will force me Force Quit PT 25ghosts Pro Tools TDM Systems (Mac) 0 03-02-2009 01:30 PM
Pro Tools 7 will NOT force quit... soundfx Pro Tools TDM Systems (Mac) 2 04-20-2006 03:04 PM
Pro Tools must force quit to quit losttimestudios Pro Tools TDM Systems (Mac) 3 03-21-2005 09:32 AM
