Old 10-24-2015, 09:25 AM
tchipman tchipman is offline
Default Moving very old session to new glyph
Hi.....I've got an old session (PT 6.something) and I want to get as much of it as I can into the newer Glyph drive.
Can I do it this way and not corrupt the drive on the iMac?
1. unplug new Glyph
2. plug in old ..drag old session to desk top
3. unplug old and plug in new Glyph
4. move session from desk top to new Glyph
I really don't want to corrupt that iMac drive (did that once) will this work?
Tim
Old 10-24-2015, 11:08 AM
jryser's Avatar
jryser jryser is offline
I don't see why not! I have done that numerous times with older drives. If you have access to another portable hard drive connected simultaneously and drag to that one you should be ok as well. All that being said, however, what happened when you inadvertently corrupted your iMac the first time?
A Rig: MacBook Pro Spring 2013, 2.8Ghz I7, 16GB RAM,
OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph GT 050 Qx3 1.5 TB drives Thunderbolt-FW400, Presonus Faderport. 10 REMOVED!
B Rig:MacBook Pro Spring 11, 2.33 GHz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph Portagig 62 portable 1 TB drive Firewired with 400, Presonus Faderport. 10 REMOVED!
I am the main songwriter/performer for Midwest Whitetail, Cabela's Deer Nation, Spring Thunder, and Northern Waters Series!
Old 10-24-2015, 11:25 AM
Default Re: Moving very old session to new glyph
That may work fine, but I think a better way to do it would be to open the old session and then go to File>Save Session Copy> and then check the box for All Audio Files and choose Wave(especially if this old session has the audio in SD II format) and save this session copy to the new drive
Old 10-24-2015, 11:37 AM
Drew Mazurek's Avatar
Albee's way is the way to do it!!!
www.drewmazurek.com
Old 10-24-2015, 12:48 PM
jryser's Avatar
I second what Drew said!
Old 10-24-2015, 01:11 PM
Hey thanks again you guys. You're all so good that my wife is always the one to suggest coming here first. I did wonder about all the files involved in the session. I'm still using my 002 so I can only hook up one Glyph at a time.
One time a session accidentally got saved on to the hard drive of the iMac. Nothing from that point would work right because that session was messing with whatever that drive does. A Sweetwater tech (John) finally took over my computer remotely and cleaned the whole thing up! Nice............I just don't want to do it again.
Once again thanks for your help.
Tim
Old 10-28-2015, 03:00 PM
jryser's Avatar
Let us know how it goes.
[IMG] code is Off
DAE 9126 - Glyph 3TB - Can't main session file Raganok macOS 4 02-16-2013 11:53 AM
Moving a session. eddiesound macOS 0 08-31-2011 12:57 PM
"Missing audio" when moving sessions from G5 to Glyph Blue Ridge 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-01-2010 02:30 PM
Moving session to MAC Michael Jessen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-20-2005 12:26 PM
Moving session from NT to Mac Camilo Orozco Pro Tools TDM Systems (Win) 6 07-07-2000 09:41 AM
