Old 05-24-2014, 01:46 PM
Ruin Ruin is offline
Default I/O Reset
I just reinstalled PT 10 due to an I/O issue i had mistakingly made. My input paths aren't listed and it will not allow me to create new ones causing a input path error message to pop every time i try to record enable any and all tracks. Im still kinda new to I/O setup and would really appreciate the help.
Old 05-24-2014, 05:07 PM
Bill Denton Bill Denton is offline
Default Re: I/O Reset
Go to I/O setup. Click each of the tabs, then click the "Default" button on each of the pages.
X
Note that all opinions, observations, whatever, in this post are mine, unless I'm being mean or am wrong, in which case it's somebody else's fault. I do not work for Avid (their loss)...my only relationship with Avid is that of a customer (when I'm not too poor to buy stuff, like now)...and that hot administrative assistant...that's more of a "thing" than a "relationship" (that should keep them guessing for a while...)
Just rockin'...what more is there?
Bill in Pittsburgh
Old 05-25-2014, 08:31 PM
A little "trick" to add to your bag: since a re-install of PT(or an update) often calls for an UNinstall, that can delete your settings under normal circumstances. I choose to create my own folder(on the desktop, but it can go anywhere) and store my IO and midi settings there. A complete removal of PT doesn't touch it so its easy to import the old settings into a fresh install
Old 05-28-2014, 07:52 PM
Thanks guys appreciate it. I gotta get through a couple mixes for a friend's band not mention projects with post.
Old 05-29-2014, 01:35 PM
Almost forgot to add this; if your IO refuses to cooperate, double-check that the proper audio engine is still selected under Setup>Hardware
Old 06-01-2014, 01:13 PM
Yeah I think that was the issue. I just quit everything then restarted my comp. It worked fine after
Old 06-01-2014, 02:38 PM
Here's one more "trick" for this. Open PT, but don't open a session. Go to Setup>IO and check the box for "Session overwrites IO settings"(or whatever its called) and open one of your recent sessions that has all the IO set and correct. Once the session is open, go back to Setup>IO and UNcheck that box.
C|24 Firmware reset? Marsdy Pro Tools TDM Systems (Mac) 2 09-12-2010 02:27 PM
003 Rack Reset Jedanor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-11-2010 08:00 PM
Reset 003 it.sounds 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 04-13-2010 08:26 AM
My TC-DAT needs to be reset??? Halstein Post - Surround - Video 8 10-24-2009 04:27 AM
003 reset albee1952 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-14-2007 01:29 PM
