Old 05-09-2014, 11:39 PM
anackman's Avatar
anackman anackman is offline
Default Waves 9 installer only installed AAX?
I installed my waves plugins using V9r18, the most recent on a Waves site. It seems that only the aax versions installed. When I open pro tools 10.3.8, none of my waves plugs are there. When I open pro tools 11.0.2, the waves plugs are there.
Can someone explain this? Very strange. I thought the installer included all formats, at least RTAS and AAX.
I am using a mavericks machine at a shared studio...brand new Mac Pro. Could that be an issue? Maybe compatibility with mavericks and new mac?
MAC OS Ventura
Pro Tools 2024.3
2020 iMac 27" 3.2 Ghz i5, 64GB Ram
UA Apollo Rackmount Thunderbolt + Dangerous D-Box
2x Glyph Studio 2TB Raid SSD
Old 05-10-2014, 07:01 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Default Re: Waves 9 installer only installed AAX?
Check your Digidesign Plug-ins folder for the Waveshell.dpm
(As the AAX-shell is a separate installer and seems to be working)
All your waves plug-ins are actually in your applications folder.
You will also find the .dpm waveshell in there as well.
I found in Mavericks, I needed to start PT's 10.3.9 several time to recognize all plug-ins (Out of memory issue).
Also try holding the shift key during PT's launch. This should bring the Waves rescan-plug-ins pop-out menu.
HTML code is On
Protools installer says digisupportdll not installed. Cormacokane Windows 0 03-27-2012 04:54 PM
New Waves installer.... danander11 General Discussion 18 02-08-2010 02:50 PM
Waves Installer New! K.I. Pro Tools TDM Systems (Mac) 3 12-21-2009 09:32 AM
Waves Installer K.I. Pro Tools TDM Systems (Mac) 7 12-02-2009 09:23 PM
A new Waves API installer zulunation Pro Tools TDM Systems (Mac) 0 06-28-2007 11:38 AM
