Closed Thread
Old 06-21-2013, 07:43 PM
zion zion is offline
Default Low-Latency Input Buffer
Can some tell me how this works? Is there an input buffer setting somewhere?
Old 06-21-2013, 07:44 PM
Bharath's Avatar
Bharath Bharath is offline
Default Re: Low-Latency Input Buffer
The hardware buffer size you choose in playback engine setup dialog determines that.
:: Bharath
Pro Tools Software Team
Old 06-21-2013, 07:47 PM
I thought there were two buffer settings in Pro Tools 11. One for playback as you mentioned and one for the recording input. "Low-Latency Input Buffer"
Old 06-21-2013, 08:00 PM
Let me try and be a little clearer. This was supposed to be one of the new features in Pro Tools 11 HD. As advertized. "Pro Tools 11 introduces a low-latency input buffer, which ensures low latency when recording without sacrificing plug-in performance." How does this work and were are the settings for the input buffer?
Old 06-21-2013, 08:04 PM
Bharath's Avatar
Playback buffer size is automatically set depending on the sample rate and is not user configurable. (for e.g. it is 1k @ 48k)
:: Bharath
Old 06-21-2013, 08:05 PM
mykhal c's Avatar
mykhal c mykhal c is offline
your input/record buffer is determined by playback engine setting. the playback buffer is determined by your sample rate. 44.1/48k playback track with 1024 buffer...88.1/96k at 2048. can't remember if 192 is at 2048 or 4096. i'm sure Bharath will chime back in with the facts if i missed 'em...
bassist...deep pocketz anyone???!!!
The Basschakra Lucid Soul Trip
i7 Builds - Specs and Results
HDNative | Omni | i7-3930K OC'd 4.0GHZ |
ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff
boomsounddesign's Avatar
boomsounddesign boomsounddesign is offline
From experimentation it seems it sets itself automagically. Though its a little more disappointing than you would have expected from all the advertising.
My Gear
Mac Pro (mid 2011) - 2x 2.8GHz Quad-Core Xeon, 16GB RAM, ProTools HD Native, UAD Quad.
HD IO 16x16 + Lynx Aurora 16
Solid State Logic Matrix
B&W 800 series + Yamaha HSM80s
Mojave Audio, Royer, Neumann, Audix, Yamaha, AKG and Shure mics. Focusrite ISA828, SSL Alpha VHD, UA LA610-mkii, M-Audio OctoPre, Avid Eleven Rack
Canare and Mogami cabling.
http://www.boomsounddesign.com
Old 06-21-2013, 08:07 PM
mykhal c's Avatar
how so?
Old 06-21-2013, 08:08 PM
I haven't seen a very big difference from what it used to be other than the overall performance enhancements.
My Gear
Old 06-21-2013, 08:09 PM
How is this new feature different from the way Pro Tools 10 Performs this? I thought (for Example) you could set the HW buffer to 1024 Samples for playback of Vi plugin etc. and still achieve low latency on the track recording. Maybe I'm misunderstanding what this new feature does.
Closed Thread
Input Buffer OneThousandBirds Pro Tools 11 2 09-20-2013 02:35 PM
Input/output buffer xy44 Pro Tools 11 1 06-24-2013 11:34 AM
HW buffer size and latency JPeters86 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-07-2007 11:22 AM
latency/ buffer overflow..Please someone help me ozzymau 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 02-01-2005 02:52 AM
Latency/HW Buffer Question vlad 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 06-03-2003 10:14 AM
