Accel card compatibility in Magma PE6R4
I plan on adding another accel card in my Magma PE6R4. I recall reading on the DUC there can be issues with older accel cards not working in the Magma PE6R4. Anyone know which revisions I should avoid and which are compatible. I have a line on a REV B accel card but not sure if this is one of the old cards that is not compatible with the Magma PE6R4.
Thanks |
Re: Accel card compatibility in Magma PE6R4
I worked a little more than two years with a rev B card in a PE6R4 without any problems.
Serge Hamel Mixer / Sound Designer http://www.netpostproduction.com http://immersivesoundvr.com/ |
If I remember well there has never been a problem with HD Accel cards in a Magma PE6R4, but there can be a problem with a Rev "K" HD Core card in a Magma PE6R4 in combination with some types of 'Westmere' Mac Pro's. I had this problem and Avid replaced my Rev "K" HD Core card for free.
Btw, I have 5 HD Accel cards in my Magma PE6R4-i, a mix of old and more recent cards with unknown revision numbers and they all work fine
Marc Schellekens Delta Music Belgium - Dolby Atmos Music Studio https://www.deltamusic.be Mac Pro 2019 - 3.2GHz 16-core - 96GB RAM - macOS 14.4.1 - PT HDX3 - Pro Tools Ultimate 2024.3.1 - Avid HD I/O 16x16 (x2) - Avid HD I/O 16x16 Digital - Digidesign 192 I/O - Digidesign 192D I/O (x3) - Avid SYNC HD - Apogee Big Ben - Apogee Rosetta 200 - Avid S3 - Slate RAVEN MTi2 (x2) - iConnectivity mioXL (x4) - Genelec ‘The Ones’ 9.1.6 Dolby Atmos Music monitoring (AES/EBU) with 8341A (x5) + 8331A (x10) + 7360A (x2) + 9301B - Almost all available AAX-DSP plug-ins |
Thanks for the responses Serge and Marc.
I believe Serge had previously posted he had an issue with an accel card in the Magma PE6R4 and had to have Avid update the card. |
You are right. I had a problem during installation of the magma because one of the card had to be updated.(costing more than $400.00) . The card was working great in a pci-x computer without the magma. Unfortunately I don't remember which card... After sending it to the avid dealer(CEV) for a update, I never had a problem (more than 2 years).
i think everything is ok on my rig so far...
CAZADOR RECORDING PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2 With GOD as my partner. . . I need to make my plans LARGER. |
Hi Jimmy,
I doubt because I send you two cards with the latest rev. We gave the oldest revision cards to Avid when doing some HDX hardware exchanges. Keeping all the cards with the newest rev for sale.
good to know!....i'm enjoying them very much my man
If you are going to use a Magma expansion chassis you have to make sure that you are using the current model. The PE6R4 is an obsoldete model. The PE6R4-I is current model.
Here's a video on what a PE6R4-I looks like and it also demonstrates how to install Pro Tools cards. http://youtu.be/qBkgiUKIvqs |
Pro Tools Core Rev K is the one that is incompatible or I would say having issues. If you are planning on adding another Pro Tools cards in the Magma expansion unit make sure you connect the yellow ribbon flex cable from Port B of core card to Port A of Accel or Process card.
Here's a video posted on vimeo, about Pro Tools cards installation in Magma expansion PE6R4-I unit. |
FS: Magma PE6R4 chassis w/ cable and PCIe control card | WildHoney | Buy & Sell | 1 | 10-06-2013 02:28 PM |
FS: HD3 Accel, Magma PE6R4, 192 I|O x2, Pro Tools 10 HD | blairl | Buy & Sell | 9 | 01-31-2013 11:10 AM |
FS: Magma pe6r4, pci HD accel process | doug_hti | Buy & Sell | 6 | 06-05-2012 12:43 AM |
Apogee X-HD card with Magma PE6R4 | Ramm1 | Pro Tools TDM Systems (Mac) | 3 | 11-14-2010 05:46 PM |
problem adding 6th card to magma PE6R4 | crizdee | Pro Tools TDM Systems (Mac) | 20 | 07-22-2009 02:53 PM |
