Old 01-09-2012, 01:23 AM
stargazer stargazer is offline
Default Re-opening former TDM session saved in HDX
When I open a TDM session on HDX I get this message:
"The following Plug-Ins were converted to Native because a DSP version does not exist."
Then, when I save this session in PT10.1 HDX, and reopen it, I still get this message. No big deal, but why does PT try to load the plugins as DSP versions when I saved the session with Native versions?
PT Ultimate 2022.10.0 | HD OMNI | S3 | PT Dock | EuControl 2022.4.0.78 | PT Control 2022.4.0.60
macOS Big Sur 11.6.5 | Mac Pro (2019), 3,2 GHz 16-Core Intel Xeon W, 384 GB 2933 MHz DDR4
Old 04-27-2012, 10:44 AM
bdangler bdangler is offline
Default Re: Re-opening former TDM session saved in HDX
bump. I keep getting the same error. How do I get rid of it?
Old 06-28-2012, 01:35 AM
mr.armadillo mr.armadillo is offline
Any news on this? It's annoying.
Old 06-28-2012, 01:48 AM
Bushpig Bushpig is offline
Guys,
I had this problem when testing an interim version of 10.1.xxx.
This was fixed in 10.2.
Hope that helps.
Steve Bush
www.music180.com/pros/5887
2 x Systems: MacPro 4.1 (Nehalem) 2.26 8 Core, OSX 10.6.8, PT10HD, 14 Gig RAM, PCIe HD3, 192's, Sync I/O, Midi I/O.
Old 06-28-2012, 01:10 PM
Default
No, it wasn't. I'm on 10.2
Old 01-22-2013, 07:05 AM
Has this been resolved?
Old 06-19-2013, 12:59 AM
myhrik myhrik is offline
I'm on 10.3, and I still seem to get this message on ALL my projects, even if they started as HDX sessions in the first place. I can start a new project, add some ReVibe to it for instance, as AAX DSP. It works in DSP until I quit Pro Tools and re-open the session. Then it says that a DSP version of ReVibe doesn't exist. What is causing this..? I guess it is fixed in PT11 since it is practically a new application...
Eirik Myhr
film/tv composer
Oslo, Norway
Mac Pro 2.66 GHz Quad-Core, 8 GB RAM | 192 I/O | HD2 Accel | UAD2 Duo | Mac OS 10.6.4 | Pro Tools HD 9.02 | HEAT | UAD Plugins 5.4.1 | Novation Automap 3.0
NI Komplete 6 with Kontakt 4.0 + libraries: | L.A. Scoring Strings | Symphobia | True Strike 1 + 2 | Galaxy II | Scarbee K.G.B.
SoundToys Native 3.1.1 | Waves Ren. Maxx TDM 7.1 | Melodyne Plugin 1.0.4 | Superior Drummer 2.2.1 | Addictive Drums 1.5.1 | Ampeg SVX 1.1.3
Old 09-30-2013, 11:09 AM
viaspiaggia viaspiaggia is offline
was having this issue, solved it by option-dragging the plug in question to make a copy of it, then deleting the first one.
Mac mini 2018 i7
ProTools Ultimate Native
Focusrite Scarlett 18i20
Atmos 7.1.2
hugmonstersound.com / unheardof.world
HELP, things getting jacked when re-opening saved sessions.. chucknkd Pro Tools TDM Systems (Mac) 2 04-14-2008 03:15 PM
edit & mix windows not opening in last saved place clampire 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-30-2007 06:38 PM
sends not working when opening a saved project. ashdeini 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-11-2006 06:51 PM
dae memory low when opening saved sessions gdubbs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-24-2003 07:04 AM
Opening saved files Threnody 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-13-2002 07:39 AM
