Quick fix for a instrument track that won't play
Duplicate a instrument track that is not working. The new track will work.
Yes, I know about the problem and always use aux tracks but this was a outside session. If anyone can confirm this perhaps it will help Digi fix the problem.
Ron Wasserman http://www.ronw.com http://www.imdb.me/ronwasserman http://www.fishertheband.com Mac Pro (Late 2013) 3.5 GHz 6-core Intel Xeon E5 - 32 GB Ram / 1TB Flash Storage - Avid HD I/O - Latest Mac OS - HDX3 - Latest PT Version. |
Re: Quick fix for a instrument track that won't play
We are aware of the problem and have a fix in the works.
If you show instrument in the Mix Window, is your MIDI channel set to '1' ? I saw this (again) the other day. Switching it to '1' fixed it for me.
... but does it help the chorus? |
Yeah, dup'n or making it inactive & active again will often move the MIDI channel to the next available so as Sean said, double check that it hasn't changed...
This is a huge issue and I see it was not fixed with CS2. When do you plan to resolve this?
Thanks.
Instrument track doesn't play!? | digidesigner | Pro Tools TDM Systems (Mac) | 8 | 02-18-2014 02:17 AM |
problem play track instrument | LEAR | macOS | 0 | 06-08-2011 11:00 AM |
Having problem when i play/playback the midi instrument track | yitkara | MIDI | 8 | 10-08-2010 05:11 PM |
unable to play Vacuum via instrument track | 440Hz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 36 | 06-03-2010 11:34 PM |
How do I get a MIDI track to play an Instrument | higginsdj | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 05-16-2010 04:20 AM |
