Delay Compensation and sync io
I've just started using plugins that cause latency that is beyond 100 samples or so and my primary use of protools is mixing audio to be layed back to video with the sync io. I understand how the TDM delay compensation works but I'm now having to nudge audio because I'm exceeding the limits of the compensation. Do I need to change my timeline timecode to make the audio match up to video? If I'm under the 4072 sample limit and the program is handling it all will the sync io delay the tape the appropriate amount automatically?
I can't find any info in my reference manual about this issue other than in the 'setup session' dialogue it shows total latency. It doesn't mention if this latency is applied to the tape syncing to the protools. Thanks for any info on this. |
Re: Delay Compensation and sync io
Delay Compensation Messing Up Video Sync..? | Jon_Atkinson | Post - Surround - Video | 21 | 06-07-2015 08:46 AM |
Keeping Laybacks in Sync (delay compensation and Video sync offset) | edit machine | Pro Tools TDM Systems (Mac) | 6 | 11-15-2010 11:33 AM |
Delay compensation and Sync | TLmix | Post - Surround - Video | 3 | 01-09-2006 08:31 AM |
Lip sync and delay compensation? | Erik Olsson | Post - Surround - Video | 0 | 09-13-2005 07:20 AM |
