Remix question, changing tempo?
I'm doing a remix of a song that is originally 96bpm and I'd like to bring it up to 120. Instead of just using little bits of the vocals I'd like to make a re-version as it were and use the full wav. file of the original vocal and align it to this new tempo....is there a way to do this without clipping the whole vocal file apart and then consolidating them back into one contigous file? I tried using the Time compression/expansion Audio suite effect but I keep getting a DAE error-7401.
I'll be using mostly new instrumentation but I was also wondering how to do this with one or two of the instrument audio files.
Apple Mac Pro 2.88 GHz. Intel Xeon Quad core 16 GB RAM Mountain Lion 10.8.5/El Capitan 10.11 Focusrite Saffire Pro 40 Ableton Live 10/Presonus Studio 3 |
Re: Remix question, changing tempo?
Sounds like this could be a job for "Elastic Time " in the new PT 7.4. I didn't test it until now, but you can do a search here or watch the videos on Digi's webpage.
MBPr 15" (Mid 2015) i7, PT12.4, Studio One 3, UA Apollo Quad Firewire |
I don't have 7.4. I'm using 6.4. But anyway, I figured out why the effect wasn't working. It's because I hadn't saved the audio files for this session....the effect was trying to work on the original files from the original session that I can't open...so my bad. But any way, back to the original question....is using this effect the best way to adapt audio files to a new tempo in a remix and if so, what setting work best for vocals?
If the song is at a fixed tempo, then you could just use TCE.
My work flow is as following: I normally use beat detective on one a bar at a time. I capture, analyse and seperate. Then i move the bits around until they sound the way i like at the new tempo and then on to the next bar. I feel that this give me the best result. It takes a bit of time, but i like the result in the end. |
7.4 would be, no joke, absolutely amazing for accomplishing this
forget TCE-ing everything I'm serious once you go PT 7.4, you can never go back the time-stretching algorithms are the most amazing and clean that I've ever heard in my life
iMac 2017 4K Quad 3.6 GHz i7 32 GB RAM Presonus 1818VSL PT Ultimate |
pitch n time is the best software plugin to do this...elastic audio is not bad...but pnt is much better and creates less artifacts....you can listen to my remixes on myspace.com/joesmoothmusic
js |
i have to disagree
pitch n' time has always been the best....until now but it can take a little bit of getting used to the best way to use EA first as in, using it on tick-based tracks with current tempo information properly in place use a real-time algorithm to adjust and then the XFORM to finalize with the best math possible..... I've already made entire songs that are complicated both musically/instrumentally approx 50% longer with constantly variable new tempo changes without exhibiting a single audible artifact using EA. I've never seen pitch n' time be able to accomplish that kind of insane time-stretching. but alas, we are all entitled to our opinions
Noob question about changing tempo | Erelen0113 | Pro Tools M-Powered (Win) | 1 | 03-01-2011 01:37 PM |
Question about MIDI and changing tempo | jasonguitar | MIDI | 1 | 09-09-2007 04:51 AM |
calculate tempo remix | ModaRecords | Pro Tools TDM Systems (Mac) | 8 | 03-03-2006 08:48 AM |
Remix tempo | ModaRecords | Pro Tools TDM Systems (Mac) | 2 | 05-21-2004 07:54 PM |
question about tempo changing | DANIELJ | General Discussion | 0 | 04-23-2003 12:17 AM |
