Old 04-21-2006, 10:08 PM
GtrDude GtrDude is offline
Default Adding a compressor after recording
I was wandering what would be the best way to add a compressor on a recorded file?
One way would be to highlight the entire track and add a compressor that way. I have a feeling this may not be the "right way" though.
Would it be better to do it using Aux input and Bus it?
For an example the way I add a reverb is to add Sterio Aux>Insert reverb> in sends add Bus1-2> in I/O make sure Mic/Line 1-2 is on> and Analog 1-2 under that in the I/O view.
Would this be the way you would add compressor.
Thanks for your help
GtrDude
Old 04-22-2006, 02:11 AM
ejwells's Avatar
ejwells ejwells is offline
Default Re: Adding a compressor after recording
It's best simply to insert one on the track.
As a rule, insert compressors and eqs.
Buss verbs and delays.
That's not to say that there aren't instances when you'd buss to an aux with a compressor on it, but for guitars and voice, and other individual instruments, I always insert.
Pro Tools 10.3.3 | HD Native | HD I/O 8x8x8 | Mac Pro 8 Core Westmere | 24GB RAM | OSX Lion 10.7.4 | API 3124 | Chandler TG-2 | UA 4-710d | Empirical Labs Distressor EL8X | Kemper Rack |
Drum Mic'ing & Adding Compressor? ASTR macOS 14 03-25-2013 11:33 PM
Adding a Click While Recording (Mid Song). Anglister Pro Tools 9 6 05-06-2011 04:48 PM
Help with Reverb feedback when adding Compressor brandin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-09-2006 03:22 PM
compressor for recording MerkRecords 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 08-22-2005 05:49 PM
recording VOX and adding EQ's Rifpop 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-27-2004 06:04 AM
