HOw to Reset Min:sec
Well this is probably a rookie question, but I can see no way to do this, so I'll you pros. I like to have a couple measures in front of the start of all my sessions. It just makes things easier for me to see and also allows me a little space at the front to park something if I need to. In normal audio sessions, I just renumber the bars so 3 becomes 1 and I get 2 measures up front (-1 and 0) What I can't seem to be able to do is get the Min:Sec to begin at 0:00 at the new measure 1 beat 1. Min:Sec always starts at the very beginning of the session screen. I can change the Timecode on the setup menu easily enough, but there doesn't seem to be an equivalent way to do it with the Min:Sec.
There HAS to be a way to do that, but if there is, I'm not seeing it and can't find it in the manual either. I'm clearly not searching for the right term in the manual. Can one of you kind souls please point me in the right direction on this? Thanks
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC |
Re: HOw to Reset Min:sec
Is this because you can't have negative time?
cheers Mike Aiton BSc (hons) Audio Consultant, Dubbing Mixer/Sound Designer & Journalist BAFTA member IPS member ---------------------------------------------------------------------- www.mikerophonics.com |
And, hey, negative time didn't stop Stephen Hawking! He even used imaginary numbers!
At least you can vote for this :
http://protools.ideascale.com/a/dtd/...ne/129931-3779 http://protools.ideascale.com/a/dtd/...ter/29524-3779 .
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
I believe so, not possible.
But you could put your song /project to the HH:MM:SS:FF 01:00:00:00 and the session start time to whatever you need earlier. And mentally disregard the 01-hour ... . Like in movie post production, where the start of the movie is 01:00:00:00 and everything technical/leader/countdown is prior to that.
Yes, I know. Thanks so much. What would be nice is being able to have multiple 0 points. That would be very useful for video game composers who often create multiple sequences with different layers that will be used depending on the state of game play and the players actions/choices. It might be that each theme is, say, 1-2minutes or so, but you may have 8-12 variations of it. If you put, say, a couple empty measures between each one and could renumber those measures to 1, along with timecode AND Min:sec...it'd make life easier. You could have all of them in the same session, each starting and stopping with their own measure/beat/min:sec/timecode attached.
Many of us have been hoping for local zero FOREVER! At least since before the beginning of time...
http://protools.ideascale.com/a/dtd/...er/222102-3779 |
Zero Reset? | spindlebox | Pro Tools 11 | 6 | 03-16-2015 05:49 PM |
I/O Reset | Ruin | Pro Tools 10 | 6 | 06-01-2014 02:38 PM |
Reset 003 | it.sounds | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 04-13-2010 08:26 AM |
My TC-DAT needs to be reset??? | Halstein | Post - Surround - Video | 8 | 10-24-2009 04:27 AM |
003 reset | albee1952 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-14-2007 01:29 PM |
