First time user, Pro Tools ii launch error
Hi there,
I just bought, installed and registered Pro Tools 11 student edition. When I double click the Pro Tools icon I get this error message: "Pro Tools 11 could not be loaded. Please contact the software publisher for support using this software> Error details: Import DLL MSVCP100.dll could not be loaded." Any help would be greatly appreciated! Thanks, Chris |
Re: First time user, Pro Tools ii launch error
Welcome to the forum,
Start with Help Us Help You some addition question: Have you provided proof that you qualify for the Student license Has the license been deposited into your iLok account Have you moved the license from your account to your iLok key
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
No, the Pro Tools 11 Bundle license shows on your iLok account as being activated and installed on your iLok 2, so the authorization part is all correct.
You should follow the instructions that Craig F gave, and list all of your system specifications. |
Ok, here's the report. Let me know if I did it right or need to post more information.
***** Start of Report ***** -------------------------------------------------------------------------------- <<< Computer Overview >>> -------------------------------------------------------------------------------- < ID > Host Name: Christopher-PC Workgroup: WORKGROUP < Computer > Model: ASUS CM6630_CM6730_CM6830. Desktop Serial Number: C7PDCG000HC9 Chassis: Desktop Mainboard: ASUS CM6330_CM6630_CM6730_CM6830 Serial Number: MT7025018004188 BIOS: AMI (OEM) 4002 06/26/2012 Total Memory: 8GB DIMM DDR3 < Processors > Processor: Intel(R) Core(TM) i5-3450 CPU @ 3.10GHz (4C 3.39GHz, 3.4GHz IMC, 4x 256kB L2, 6MB L3) Socket/Slot: FC LGA1155 < Chipset > Memory Controller: ASUS Core (Ivy Bridge) DRAM Controller 100MHz, 2x 4GB DIMM DDR3 1.6GHz 128-bit < Memory Module(s) > Memory Module: A-Data EL64C1C1624Z1 4GB DIMM DDR3 PC3-12800U DDR3-1600 (11-11-11-29 5-40-13-6) Memory Module: A-Data EL64C1C1624Z1 4GB DIMM DDR3 PC3-12800U DDR3-1600 (11-11-11-29 5-40-13-6) < Video System > Monitor/Panel: Philips (1920x1080, 37.9") -------------------------------------------------------------------------------- ***** End of Report ***** |
Hi
Thats not the correct report as half or more is missing. Use this one here and post the whole thing. http://www.sisoftware.co.uk/?d=dload...dl_all&l=en&a= Choose the correct OS version for you and run the installer Best Regards Christopher
Unfortunately, when I follow the video instuctions to click the 'hardware' tab within Sandra and then double click 'computer overview' it generates a blank report.
This is with the free version, Sandra lite. |
I could really use some help guys. My new copy of Pro Tools 11 does not start, same problem. I need this for my Berklee online classes. I am trying to give you the report you want, but when I follow the instructions in BernoniStudios' video, Sandra will act like it is generating a report (green circle) and then produce nothing (blank window).
I would even pay for Pro Tools support if it comes down to it, but I can't find an option for Pro Tools 11, just the versions that comes with the M-box or Pro Tools HD. I honestly don't know what to do. My computer functions fine with Ableton Suite and other DAWs and software. Thanks, Chris |
Please disregard this post as I just spent a couple hours with an Avid tech and he could not fix the error. We think my registry is to blame so I am looking at a reformat or buying a new computer.
Thanks for your time! Chris |
First Time Pro Tools User | String Breaker | Pro Tools 9 | 9 | 08-27-2011 06:32 PM |
New user - can't launch Pro Tools 9 | lanstrad | Pro Tools 9 | 1 | 05-02-2011 07:43 AM |
Pro tools LE 7.1 won't launch from new user account | Mairead | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-03-2007 08:25 AM |
CAnnot Launch Pro tools 7.1 TIME SHIFT | caipo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-19-2006 01:03 AM |
Pro Tools Le 6.1 Crashes every Time I launch it ?? | Pop-cycle | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-04-2003 10:01 PM |
