Old 12-23-2016, 01:05 AM
stargazer stargazer is offline
Default PT HDX 12.7, 10.10.5 (Yosemite), MacPro4,1 (Nehalem)
MacPro4,1 is not officially supported.
http://avid.force.com/pkb/articles/e...m-Requirements
Anybody tried?
PT Ultimate 2022.10.0 | HD OMNI | S3 | PT Dock | EuControl 2022.4.0.78 | PT Control 2022.4.0.60
macOS Big Sur 11.6.5 | Mac Pro (2019), 3,2 GHz 16-Core Intel Xeon W, 384 GB 2933 MHz DDR4
Old 12-23-2016, 01:29 AM
strangeLoop strangeLoop is offline
Default Re: PT HDX 12.7, 10.10.5 (Yosemite), MacPro4,1 (Nehalem)
Yes, I have the Nehalem MacPro 4,1 - ProTools 12.7 - 003 Rack.
It seems to work fine except for the jerky cursor movement, but I don't get much past 20 tracks.
John Clavin - AKA: Old Horseface
Old 12-23-2016, 04:03 AM
Hanswurstlsepp Hanswurstlsepp is offline
All fine here so far. No problems with cursor movements or anything else.
Might depend on graphic card(s) ?
Cheers, STeff
MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected  OSX10.15.7  Pro Tools|HDX Ultimate 2023.6  HD I/O&192Digital&96&96i I/Os  D-Command ES  4xUnitor8 & 2xAMT8
Old 12-23-2016, 08:36 AM
T-Low T-Low is offline
I have an 4.1 Mac Pro ( upgraded to 5.1 specs ) with NVIDIA GeForce GT 120
HD Native PCIe card
PT 12.4 + Yosemite works great
but everything above on Sierra PT 12.5 / 12.6 / 12.7
is a disaster with a buffer at 64 ... CPU spikes all over
Old 12-23-2016, 02:51 PM
I´ve replaced the GT120 with a Mac Radeon HD 6870
but got the same CPU spikes with Sierra ...
Old 12-25-2016, 08:28 PM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
Anybody tried?
Install Sierra. and 12.7, very solid.
BUT on a 4.1, you'll need to do 2 things first.
Flash your 4.1 to 5.1, instructions are on the web.
Purchase one of these
http://www.osxwifi.com/apple-broadco...nd-macpro-2010
With the 5.1 flash, and the newer version of Wifi BT card,
Sierra will install completely.
I did the above, but went further, and installed 2X 6 core processors to replace my 2X 4 core, and installed 1333mhz memory.
SO for $770 USD, its now a supported machine, not to mention, it became a 2012!!
IMDB
Old 12-26-2016, 12:29 AM
Bushpig Bushpig is offline
Hi TVPS,
Thanks for posting this info. I have two 4.1 MP's I'm on the verge of trying the updated 5.1 firmware with. Do you know if all 4.1's need this newer Bluetooth card? Or is it only certain ones? I can't seem to quite decipher the hardware report on my machines to know whether I need to swap out the BT cards.
I had read somewhere vaguely something about the BT card being an issue when attempting to run Sierra, but never got much further with investigating, so thanks for the reminder to look into this.
If you have any helpful links you could post that I could use to follow up on this more, that'd be most appreciated.
Regards.
Steve Bush
2 x Systems: MacPro 5.1 (Nehalem) 2 x 2.26 Quad Core, OSX 10.9.5 (Mavericks), PT10.3.10HD, 32 Gig RAM, PCIe HD3, 192's, Sync I/O, Midi I/O.
Old 12-26-2016, 06:53 AM
drums77's Avatar
drums77 drums77 is offline
I have problem with 12.7 HD driver on a Westmere 5,1 MacPro with Yosemite. Now I'm back to 12.6
Mac Pro (Mid 2010) Six Core 3.33GHz macOS 10.14.6 MSI Radeon RX 560
Pro Tools | HDX, HD I/O 16x16, HD I/O 8x8x8
Pro Tools Ultimate 2022.9
MacBook Pro (Mid 2012) i7 2.3GHz macOS 10.15.7
Pro Tools 2021.12
Apogee Duet
Old 12-26-2016, 02:10 PM
Originally Posted by Bushpig View Post
Hi TVPS,
Regards.
Steve Bush
Steve,
The updated firmware is a breeze to install.
I linked above to the new Wifi/BT card needed to have Sierra install on a 4.1 flashed to 5.1
Its essentially a card for a 2013. I bought one, and can vouch for these people.
You will remove your existing BT AND Wifi card. and install the new intergrated one, don't forget to order the BT extension cable also.
You really don't need the new processors or 1333 memory to install Sierra. But it helps overall performance.
Im running 12.7 on 10.12.2, and its rocking.
IMDB
Old 12-27-2016, 02:48 AM
TVPS,
Hi. Thanks for the reply.
Good to hear. Have been a bit nervous about trying this part of the operation and borking my machine if it doesn't work smoothly. I have two identical (as far as I can tell, as they were bought at slightly different times) 2009 4.1 MP's, so at least I have an emergency backup if I try one at a time. Where did you get your firmware updater from? Was it the Netkas.org forum?
Sounds good. Question though. Did you discover you needed to replace your BT and WIFI cards because they weren't the Apple installed Broadcom ones?? I see from one of the Netkas forums that there is mention of a non-Broadcom card that came with some 4.1's.
>>>> Seems this affects the Atheros cards, as the one was fine, it has an Apple branded Broadcom BCM, and the "didn't see disks" one had an Atheros AR5BX86 Apple branded card. <<<<
If you have any links to the research stuff you did, that would be really handy.
Yeah, I'm not too bothered about doing that sort of upgrading just yet. As long as I can get this initial part of the process running smooth, I'm all set to try a CPU upgrade at some point in the future.
Thanks again for your time and help with this.
Regards.
Steve B.
2012 Mac Pro upgrade to Yosemite -- where to get Yosemite install??? WildHoney Pro Tools HDX & HD Native Systems (Mac) 7 07-28-2020 01:45 AM
MacPro4,1 Nehalem internal SATA recommendations stargazer macOS 9 11-13-2015 08:13 PM
pro tools 11 on 3.33 ghz nehalem? mightyduck Pro Tools HDX & HD Native Systems (Mac) 4 09-14-2014 05:39 PM
MacPro4,1 optical out -> Avid HD I/0 not working Hanswurstlsepp macOS 3 08-13-2012 01:15 PM
Nehalem YES - but which one? Peterjk Pro Tools TDM Systems (Mac) 21 05-28-2009 06:03 AM
