Old 03-24-2015, 02:08 AM
mr.armadillo mr.armadillo is offline
Default Output video and capture at the same time?
Here's what we need to do:
Output Pro Tools video through Blackmagic Card to client and talent TV and re-capture the same source in the same Mac for internet streaming services with video or Skype. Anyone had any success doing that? We're looking into the BM Decklink Duo Card, but not sure if it works.
Old 03-24-2015, 04:57 AM
Default Re: Output video and capture at the same time?
I don't think it's possible to capture an input of a card while playing back something different from the same hardware and a different program.
Maybe this exists but I think not even NLEs can do this. It would be like capturing in the background while working on a project and all via the same hardware.
I think you'd need at least another card or another computer to do this.
But maybe I'm wrong.
Frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron
Old 03-24-2015, 06:36 AM
We've worked with Skype like this for years: Outputting video via Blackmagic (PCIE) HDMI (to client screen) and capturing via SVideo with Canopus ADVC100 (FireWire) at the same time. Unfortunately, the latest Skype version doesn't support that anymore.
Old 03-24-2015, 06:39 AM
Yes with two different video devices. I thought you meant doing all of this with a single video card on the same machine.
Old 03-24-2015, 06:48 AM
The DeckLink Duo supports 2 independent playback / capture streams.
https://www.blackmagicdesign.com/pro...specs/W-DLK-01
Old 03-24-2015, 10:43 AM
Jeffrey Talbot Jeffrey Talbot is offline
I've got what I think is the latest version of Skype for Mac... 7.5, and it has a nice screen sharing function built in.
They way I work is to output thru a BM card for talent and a producer/director to see, and then just use the built in video window in PT for me to see. With 2 monitors, this works really well.
Skype will allow you to share a screen with your contact, and one of the screens you can select is the built in video window on PT. Add some good audio routing, and the folks on the other end get basically the same thing you are trying to accomplish, but in a much easier fashion.
Can't comment on what the vid looks like on the other end, but most likely limited to the internet connection speeds than video processing....
Old 03-24-2015, 10:46 AM
Can't you already do that with onboard OS X features? (Screen-sharing and face-time). Even without Skype.
Old 03-24-2015, 12:46 PM
Ryan Young's Avatar
Ryan Young Ryan Young is offline
Been trying to successfully use Screen Hero to route audio and monitor the video window without sync issues. Kinda works.
-Ryan Young
•2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Additional Systems
•2010 Mac Pro 2 x 2.66 GHz 6-Core Intel Xeon - 48 GB 1333 MHz DDR3 (OS 10.14.6) •HD Native PCIe, 192 I/o, 96 I/o, Pro Tools Ultimate •McMix (x4), McControl (x1), JLCooper Surround panner for D-Command ES, Avid Control •Blackmagic Intensity Pro (HDMI) •7.1.4 Room with JBL LSR4300 series
•2017 MacBook Pro 2.8 GHz i7 - 16 GB 2133 MHz LPDDR3 (OS 10.14.6) •HD Native TB, HD Omni, Pro Tools Ultimate •McMix (x1), McControl (x1), Avid Control * or * D-Command ES Main Unit •Fed into whichever system is the main system
Old 03-24-2015, 01:15 PM
Sadly, Apple has stripped out screen sharing with FaceTime. Used to work... not any more.
HTML code is On
Which video capture card can send H.264 video out to a TV from PT11 jgagne1 Pro Tools 11 1 01-16-2014 12:59 PM
Video Output From Quick TIme nomatik Pro Tools TDM Systems (Mac) 12 11-29-2006 02:11 PM
7.2 bug? No time stamped video after capture? scott_cannizzaro Post - Surround - Video 2 10-03-2006 08:36 AM
Video Capture saintkev77 Post - Surround - Video 27 06-13-2006 01:35 PM
PT III and Video Capture PatM Post - Surround - Video 1 02-05-2003 09:39 AM
