Old 06-04-2009, 05:18 AM
midnightrambler midnightrambler is offline
Default Fades Clicks Etc When Using Elastic Audio
Can someone, for the love for God, explain to me what the hell is going on with Elastic Audio and crossfades?
- Why do clicks sometimes sound despite there being crossfades between regions?
- Why do clicks sometimes sound at the START and END of a crossfade?
- Why do clicks appear when 'consolidating' multiple regions with crossfades?
- Why do clicks appear when 'disabling' tracks with multiple regions and crossfades?
Are crossfades just a no-no when using Elastic Audio or what?
Old 06-04-2009, 05:27 AM
Stig Eliassen's Avatar
Default Re: Fades Clicks Etc When Using Elastic Audio
The general consensus seems to be that it's better to consolidate all regions and fades before using elastic audio.
Old 06-04-2009, 11:52 AM
DigiTechSupt's Avatar
That is correct. You should do all your edits/crossfades either before or after using EA.
Avid Audio Tech Support
Support FAQ
Old 06-04-2009, 12:14 PM
Ok thanks. For some reason I was under the impression I could do what I like with audio in Pro Tools. My mistake.
Old 02-23-2011, 03:57 PM
naughty G naughty G is offline
I believe this is a bug, and hope it will be fixed. It has been logged by Digi/Avid support.
You can *never* do all edit before using EA, because the whole point of PT is that you carry on editing as you go along! It would completely defeat ProTools reason of being not to be able to do any fades on any region, regardless of EA or not.
If fades on EA tracks weren't supported, the functionality would simply not be there to start with!
Still running PTHD TDM 10.3 in my studio, it never goes wrong.
PT Ultimate 2018 on the laptop, with all the bells and whistles through CoreAudio.
Old 02-23-2011, 04:11 PM
Sure, I do it all the time.
  • edit
  • fades
  • consolidate
  • EA
  • commit EA
Would it be better to be able to skip consolidation? IMO - yes.
Old 02-23-2011, 04:57 PM
O.G. Killa's Avatar
O.G. Killa O.G. Killa is offline
+1
Derek Jones
Sound Engineer / Producer / Composer
Derek Jones Linkedin
Megatrax Recording Studios
Megatrax Studios Yelp Page
A-list Music Artist Page
Old 02-23-2011, 07:16 PM
Fix Fix is offline
++1
Old 02-23-2011, 07:31 PM
Obviously it would be better, but the current way that Pro Tools uses fades (actual audio files, rather than real-time fades) can create problems when used in conjunction with EA.
My info was how to work with Pro Tools to avoid problems with it's current configuration - the problem was stated, I replied with what caused it and how to avoid it. If there were a magic wand that I could wave to make it work the way it 'should' or that you 'want' I would do it in a nanosecond. As it is, this is the way it works and, until the underlying mechanism of how Pro Tools works with fades, this is the way it will be.
Support FAQ
Old 05-23-2011, 02:11 PM
jturner jturner is offline
So... wait. I am running into this problem right now, and am fairly new to Elastic Audio. I can't use EA on anything but a single region with no other contiguous regions? This can't be right. Seriously, what if I have consolidated, but there is another edit to be done after EA has been used. I can't crossfade the edit? I am really having trouble getting my head around this. Seriously... timing decisions can happen pretty early on in a composition. If you use EA to enact those decisions, no other edits can be made without introducing clicks that you cannot address? This doesn't seem realistically usable.
Although I accept that many people are using it to great results, so there is a very good chance I am missing something...
BTW, that may be the bitchiest response by tech support I've seen... and after only 2 (1 fairly reasoned) responses. Weird.
9.0.5b messes up fades with x-form elastic audio huzzam macOS 1 10-13-2011 08:49 AM
How do you get fades to render when you've used X-Form in Elastic Audio? EricWillhelm Pro Tools 9 2 12-10-2010 11:50 AM
Elastic Audio - Fades pop Farmer Dave Pro Tools TDM Systems (Mac) 12 01-25-2010 10:21 AM
Elastic Audio and Fades - artefacts at fade boundary WildHoney Pro Tools TDM Systems (Mac) 12 11-26-2008 01:18 AM
Pops, Clicks, and Fades jon one 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-28-2005 04:29 PM
