output to headphone jack on imac
i finally got pro tools 10 to record through my eleven rack but my monitor speakers are hooked into the headphone jack of my imac and i hear nothing! in playback config i have it set to eleven rack - seems like the only way it will see my guitar to record. question is - how to i tell pro tools that my output is the headphone jack? p.s. very new to pro tools since i havent been able to get it working for a lonnng time! had to quit using fast track pro since its not supported in mac os10.11!
Re: output to headphone jack on imac
You normally don't. And normally don't want to use the Mac audio.
It's best to connect your monitors and headphones directly to the Eleven Rack. If you have to monitor through your Mac you can create an aggregate audio device (go into Audio/Midi setup audio panel and edit what is un the Pro Tools Aggregate IO device to have the Eleven Rack and Built-In output.). Aggregate IO tends to work worse than just using the interface by itself. There are many many posts on the Web describing howe to work with aggregate IO. Did I already mention you are better off working with the Eleven Rack by itself? Oh yes I did.... |
I have seen the stupid issue of having to hover (and other things).....PT10 came with my eleven rack (got an updated driver to make it work in osx10.11). I guess its back to garageband!!!!!!!
Or you could roll back to OSX 10.9.5 or move on to PT12. You should have checked for compatibility BEFORE going to ElCrapitan.
Not getting output from headphone jack on Thunderbolt Bridge | Cartoonmoon | Pro Tools HDX & HD Native Systems (Mac) | 1 | 09-03-2014 06:43 AM |
No headphone jack output - Meters showing output | Hotcrazyfruit | Eleven Rack | 6 | 05-06-2012 12:09 PM |
iMac bypasses Rack 003 and goes to internal mic and headphone jack | gcharles | macOS | 2 | 01-26-2011 10:29 AM |
Replacing Headphone output jack on Mbox? | davidsophia | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 03-19-2007 11:48 AM |
Replacing Headphone output jack on Mbox? | davidsophia | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-09-2007 10:39 AM |
