#81
Re: Occasional headphone out problems with Mbox 3 Pro
The second MBox Pro (3G) AVID sent me was a little more reliable than the first one I had. Headphone sockets were better, but soft limit was pretty useless on hot condenser microphones. The main problem I have found, however, is with the handling of MIDI. Loads of missing and hanging notes on playback to external instruments. Yet, when I run the MIDI instruments via my Command|8, the problems go away. What a bummer! I have a new RMA code for another replacement. Will it be worth it? Third time lucky, perhaps! Wes |
#82
hi guys just been reading all the disapointed posts on here and its not looking good. the headphone problem i hear people talking about is kinda messed up but the problem im having is im getting sound from amy a and b headphone outputs but only in mono. ive messed with everything to try and get stero but no luck. ive owned my pro for one week. is this a problem or am i missing something i havent pressed.
#83
Unfortunately, this is what happens dude. I had the mono [bleep][bleep][bleep][bleep] for a while, and a heap load of other things. I'm on my second unit, but this once can't handle basic MIDI, let alone SysEx dumps. I've been promised a new one from AVID, but this is the last time, if the next one is faulty I'm going over to another brand - MOTU may be!
#84
One simple question - are all mbox pro units affected of all this problems posted here?
regards wasserwerk |
#85
I don't think they are, some people swear by them, and reckon they're the tops! Jury's still out for me. I'll report back after I've tested replacement number 3.
#86
If there are problems, they exist from the beginning? Out of the box? Or will they come over time?
#87
I think "intermittent" is the word I would use. They can be working one minute but not the next. The first unit I had was like that. The one I have now, the headphone sockets have only failed once, but I have identified a few problems with MIDI handling, which makes it unusable. Remember, this is a top notch bit of kit, and likely to be used in semi-pro and pro environments, so it has to be completely fit for that purpose, out of the box, and for the duration of the warranty. If you're in doubt, return to sender!!!
#88
I opened a new thread for this, but wanted to add to this thread for the record. I know Avid is working on this:
Well, it looks like I ran into this as well. Everything was working perfectly yesterday, and tonight, I loaded my test session and nothing is coming through either headphone jack. Both jacks are set to receive Stereo Mix 1, and all other outputs work fine, 1/2 to my studio monitors, 3/4 to my headphone amp, and 5/6 (as a test) back into my mixer. The A and B headphone jacks are just silent. I can do everything I need to do, but this is a little annoying, and I know there have been numerous reports of this before. This MBox Pro was just purchased on August 3. -dj
iMAC 3.2GHz 6-core i7 250GB SSD (internal) 1TB SSD (external) 16GB RAM OSX 10.14.5 PT 2019.10 (last one) Waves Gold/RenMaxx v11 iZotope Ozone 8 Focusrite Clarett 8Pre Nord Stage 3 Nord Lead A1 DSI Mopho X4 |
#89
#90
Yesterday, reboots did not help. I think this might have been happening before, and I just thought my routing setup needed attention. Now I know that my routing is fine. I will try again after work.
Eleven Rack headphone port versus MBOX and other interface headphone ports | World Spirit | Eleven Rack | 3 | 02-12-2012 11:34 PM |
002 console headphone problems | mote45 | Tips & Tricks | 2 | 01-03-2006 10:15 AM |
Having Headphone Monitoring Problems | Cannibal80 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-26-2005 02:40 PM |
mbox - occasional playback distortion | bjkiwi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 04-05-2005 12:19 AM |
headphone monitoring problems.. | tim carter | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 12-11-2003 03:52 PM |
