Old 02-19-2019, 02:11 PM
Rockman413 Rockman413 is offline
Default 32bit float-point audio recording?
Hi there,
I'm a little bit confused about the 32bit audio thing. In my understanding, if I'm recording a virtual instruments signal, I pushed it up all the way high to +50dB and record it into an audio track, yes it will sound clipped/distorted. But If I use clip gain by -50dB, it should be exactly the same signal as normal. So when printing the stems, as long as I'm doing everything with 32bit float point audio, I shouldn't worry about clip/distotion of volume over 0dB.
am I correct?
Mac Pro 3.0G 8 Cores PT HD use with Ensemble Thunderbolt
Old 02-19-2019, 02:17 PM
amagras amagras is offline
Default Re: 32bit float-point audio recording?
Why would you do such thing?
amagrasmusic.com
Old 02-19-2019, 02:23 PM
Emi's Avatar
Emi Emi is offline
I think it only works when you bounce internally, or print a mix. However it doesn't help when tracking...I mean, real tracking, through AD converters because you'd clip the hack out of the converter, burn them, also burn the analog part of the converter and you'd end up with a f***** up track.
I happily stay at 24 bit, thank you.
Mac Mini M1 | Mac OS 12.6.1 Monterey | Avid Carbon + 2x Carbon Pre | Pro Tools Studio 2024.3
Old 02-19-2019, 02:44 PM
jeam25's Avatar
jeam25 jeam25 is online now
This ^
Avid Carbon Interface
Protools Ultimate
Old 02-19-2019, 03:26 PM
BScout BScout is offline
Originally Posted by Rockman413 View Post
Hi there,
am I correct?
Yes. But two things:
  1. Your virtual instrument may have its own internal mixer that isn't floating point so the clipping will be permanent.
  2. At some point you hit your output converters to hear things and it will clip.
It's easier to say mix decisions in Pro Tools will be free of distortion from clipping from overgaining where everything is definitely floating point (on a floating point session.) The minute you involve a virtual instrument, you are beholden to what that VI does (if you clip Kontakt, it'll be clipped on the recording Pro Tools does so there will be no recovery. It'll just be a 32bit file that stores the clipped distortion.)
Old 02-19-2019, 04:38 PM
  2. At some point your hit your output converters to hear things and it will clip.
Good point.
Old 02-19-2019, 08:02 PM
Top Jimmy's Avatar
Something most people haven't realized is that every sample in a 32-bit floating point word is actually only 24-bits.
James Cadwallader
Old 02-19-2019, 08:06 PM
I'm a little bit confused about the 32bit audio thing (...) am I correct?
You are correct in being a little bit confused, but not on the rest.
By nature of floating point math, doing a +50/+50 operation gives you "roughly" zero, but you have rounding errors from two opposite operations. Technically speaking, it is distortion even though it is so low level you cannot hear it.
Fixed point math as in TDM systems will hold true "zero+50-50=zero" which is why many dedicated hardware use fixed point instead of floating point -- but let's not go there.
If you have a 32bit float session it only means you store VI output as it is in its "native language" but whatever audio you have in the session is still recorded 24bit plus 8 unnecessary bits to begin with, because most AD/DA is 24bit fixed. Now what happens to your signal after is another story; you could process your track like hell and then print it to another track, which in 32bit session would now benefit from the situation.
All in all you could come up with a mantra "use 24bit for audio and 32bit for VI-heavy stuff" or just plain and simple think "i can afford extra 50% storage cost etc. so i'm just using 32bit for everything" or .. like what I'm doing .. wait until you have bought 32bit float AD/DA
Old 02-19-2019, 09:27 PM
wwittman wwittman is offline
How does knowing that, or repeating it, change anything in terms of your actual choices?
William Wittman
Producer/Engineer
(Cyndi Lauper, Joan Osborne, The Fixx, The Outfield, Hooters...Kinky Boots!)
32Bit Float with Pro Tools 11 RichS Pro Tools 11 3 04-13-2017 06:38 AM
Recording: 24bit vs. 32bit float WombatStudio.Org Tips & Tricks 55 10-05-2014 03:41 PM
Using 32bit Float Point DonaldM Tips & Tricks 52 06-27-2014 01:44 AM
32bit float (16.8)/(.24) import PROBLEM donrey Pro Tools TDM Systems (Win) 14 05-20-2006 12:05 PM
The 32bit float advantage ptnerd Pro Tools TDM Systems (Mac) 22 11-19-2005 10:26 AM
