Re: A Chassis Question...
I'm using a G4 Dual 1gig Quicksilver with a Magma 7 Slot Expansion Chassis also. I don't have the serial number before right now but it is a 32bit chassis with the older flat cable versus the newer round cable. I have the following installed in slot numbers listed below and all is well:
1) HD Core 2) HD Accel 3) HD Process 4) HD Process 5) HD Process 6) ATTO UL3D SCSI Card with three 10,000 RPM Segate Cheetah Drives 7) ATA 133 Card with 2 400gig ATA 133 Segate drives for backup and sample storage. As you can see, my chassis is "stuffed"! 1.5gb Ram, Pro Tools 7.1cs4, Logic 7.1 mainly for older native projects I've done and using its virtual instruments when developing tracks before taking them to Pro Tools.
Mac Pro Early 2009 3.06 Six Core 48gb ram, Pro Tools 10.3.10, HD6 Accel, Pro Tools 2021, Macbook Pro, Magma PE6R4i, Yamaha DM2000 Console, Logic 9 and 10, Apogee Big Ben, 10pcs HD 192's, Benchmark DAC-1, Distressors, API, Neve, Rupert Neve, Dangerous, Lynx, Manley ELOP+, Massive Passive, VariMu, Neumann, Peluso, A-Designs Hammer 2 & Nail, Empirical Labs, Drawmer, Lexicon U87, Bricasti M7, dbx, Cranesong, SSL 500 G-Bus, Custom Audio Germany, Dynaudio, Focal, Yamaha, TC Electronic, Mapex Drums, SPL |
Awesome. Thank you for the detailed info for your system.
That seems veeeery similar to what I'm going for. I don't want to assume anything... I'm trying to stay on PT 6.9 with OS 10.3.9, were you using your setup on pre-V7 with stability as well? Thanks!
G4 dual 1ghz QS (1.5gig RAM) / OSX v10.3.9 / HD4 / AD8K / PT v6.9 |
Hi Proxy,
Yes I was using PT 6.9 with OS 10.3.9 and all was stable and fine. I upgraded to PT 7 to take advantage of the dual processor support for my RTAS software instruments. I'm actually thinking about Carbon Cloning my current system and installing PT 7.2 on a new drive and see how it works on my Dual 1gig Quicksilver
I am wondering about upgrading my HD3 Accel rig with a Digidesign Expansion|HD 6 Slot Expansion Chassis. But I understand from the Digisite and the Expanded Systems Guide that there is a slight decrease in the number of instances of certain RTAS plug-ins. Are some you users willing to explain which RTAS plugins they are referring to and your experience about this? It is also said that there is an increase in the monitoring latency of RTAS virtual instruments. This is seemingly most apparent when playing instruments in real time and is said to be compensated for upon playback. Is the Automatic Delay Compensation workable as mentioned in the Expanded Systems Guide? Looking forward to hear from you. Best regards, Tord Stemland Pro Tools 7.1cs8_HD3 Accel_PCI_ Mac Dual 2,5 GHz 4,5GB_OSX 10.4.6 1 x 192 I/O with AD Conv. 3 x 96 I/O Big Ben D-CMD24
PT 7.3.1cs4-HD 6 Accel-G5 Dual 2,5-7GB RAM-10.4.9-1 x 192 i/o with 16 inputs-3 x 96 i/o-BigBen-ICON D-Command 24-HD Expansion Chassis |
Magma chassis question | Bookerv12 | Pro Tools TDM Systems (Mac) | 2 | 09-30-2010 09:08 AM |
SBS Bit3 chassis question | JNS | Pro Tools TDM Systems (Mac) | 4 | 03-23-2010 08:33 PM |
Expansion Chassis question | MB2001 | Pro Tools TDM Systems (Mac) | 2 | 07-05-2006 08:41 AM |
Expansion Chassis Question | ProTooler | Pro Tools TDM Systems (Mac) | 2 | 02-07-2003 04:30 PM |
expansion chassis question | digidesigner | General Discussion | 0 | 11-26-2001 10:42 AM |
