Old 04-20-2013, 02:48 PM
broken81 broken81 is offline
Default Protools 10.3.3 has a 24 minute session length?
When I zoom out it just turns grey past 24 minutes. If I try and record past 24 minutes I get a "Playback has reached the end of the session" window pop up. Now there is no "open ended record allocation" option in the prefs, so how does one change or fix this so I can record a larger session?
Old 04-20-2013, 02:50 PM
Default Re: Protools 10.3.3 has a 24 minute session length?
Not sure if this matters but i'm on Osx 10.8.2
Old 04-20-2013, 04:22 PM
Ok, I just opened a old session from protools 9 and it have like two hours of time in the session. Now if I create a session with "Last Used" settings it has the same amount of time from protools 9 session I just opened. Is there some way to adjust the time so I can fix this if it ever happens again with out having to open a old session?
Old 04-21-2013, 04:38 AM
Chief Technician's Avatar
Question Re: Protools 10.3.3 has a 24 minute session length?
What is your session start time?
Old 04-21-2013, 06:58 AM
Did you look at Timecode on the timeline or just min/sec? I suspect your TC start may be causing problems.
http://www.richbreen.com
MacPro 5,1 Dual Hex, OS 10.14, PT 2020 HDX, Avid HD I/Os and Metric Halo ULN8, Avid C24.
Old 04-21-2013, 07:28 AM
Meads Meads is offline
The max session length at 48kHz is 13hrs, at 96kHz it's 6 hours and at 192kHz it's 3 hours.
So probably your session start time is way before the start of your audio material. You can change that by going to session setup (cmd+num block 2 on mac or from the "setup" menu) and change the session start time to something closer to your actual audio material start. A dialog will appear, where you should choose "maintain timecode position".
After that you'll have plenty of space to the right.
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
Easiest way to extract 7 minute portion from longer session Teej Tips & Tricks 6 06-04-2013 10:27 AM
Session Length Millz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-28-2009 02:10 AM
123 minute max record length doug_hti Pro Tools TDM Systems (Mac) 8 08-30-2006 09:39 AM
58 minute concert session seandaly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-07-2001 06:41 AM
session length? audiaudio Pro Tools TDM Systems (Mac) 5 08-17-2001 10:23 AM
