Old 09-02-2022, 12:49 PM
jivanroopa jivanroopa is offline
Default unable to link to file due to missing codec
For god sake pls anyone help me out
getting unable to link to file due to missing codec error
unable to import manually nor through shortcut also.
tring to import video from desktop itself does not contain any special characters, QT is installed, Videos are converted to 720*576 in mpeg stream clip apple dv pal format 24fps
using Pt 12.5.0
sacrlett 2i2
my system config
Model : Dell Precision M4800
Serial Number : 618****
Chassis : Dell Laptop
Mainboard : Dell 0T3YTY
Serial Number : /6183XZ1/CN1************
BIOS : Dell A06 01/02/2014
Intel Management Engine (ME) : 9.0.21.1462
System Memory
Total Memory : 8GB SO-DIMM DDR3
Processors
Processor : Intel(R) Core(TM) i7-4800MQ CPU @ 2.70GHz (4C 8T 3.3GHz, 3.3GHz/3.7GHz IMC, 4x 256kB L2, 6MB L3)
Socket/Slot : FC BGA1023
Chipset
Memory Controller : Dell Core4 (Haswell) DRAM Controller 100MHz, 8GB SO-DIMM DDR3 1.6GHz 64-bit, Integrated Graphics
Memory Module(s)
Memory Module : Samsung M471B1G73DB0-YK0 8GB SO-DIMM DDR3 2Rx8 PC3-12800SO DDR3-1600 (11-11-11-29 5-40-13-6)
Video System
Monitor/Panel : Dell Computer DELL P2419H
(1920x1080, 24.0")
Monitor/Panel : AU Optronics Generic PnP Monitor (1920x1080, F2J5X€B156HW2, 15.5")
Video Adapter : Intel(R) HD Graphics 4600 (160S 20C SM5.5 1.3GHz, 512kB L2, 2GB DDR3 1.6GHz 64-bit, Integrated Graphics)
Graphics Processor
OpenCL : NVIDIA Quadro K1100M (384S 2C SM1.2 705MHz, 2GB 2.8GHz/2.8GHz)
OpenCL : Intel(R) HD Graphics 4600 (160S 20C SM1.2 1.3GHz, 256kB L2, 1.6GB DDR3 1.6GHz 64-bit, Integrated Graphics)
D3D 11 : NVIDIA Quadro K1100M (384S 2C SM11.5 705MHz, 2GB 2.8GHz/2.8GHz)
OpenGL : NVIDIA Corporation Quadro K1100M/PCIe/SSE2 (2GB)
Storage Devices
Disk : HGST APPLE HDD HTS727575A9E362 (750.2GB, SATA300, 2.5", 7200rpm, 16MB Cache)
Disk : Samsung SSD 850 EVO mSATA 250GB (250GB, SATA600, SSD, SED)
Optical : HL-DT-ST DVD+/-RW GU90N (SATA150, DVD+-RW, CD-RW)
Logical Storage Devices
New Volume (D:) : 342GB (NTFS, 4kB) @ HGST APPLE HDD HTS727575A9E362 (750.2GB, SATA300, 2.5", 7200rpm, 16MB Cache)
Hard Disk (C:) : 232GB (NTFS, 4kB) @ Samsung SSD 850 EVO mSATA 250GB (250GB, SATA600, SSD, SED)
Hard Disk : 508MB (NTFS, 4kB) @ Samsung SSD 850 EVO mSATA 250GB (250GB, SATA600, SSD, SED)
New Volume (E:) : 357GB (NTFS, 4kB) @ HGST APPLE HDD HTS727575A9E362 (750.2GB, SATA300, 2.5", 7200rpm, 16MB Cache)
Hard Disk : 96MB (FAT32, 1kB) @ Samsung SSD 850 EVO mSATA 250GB (250GB, SATA600, SSD, SED)
Optical Drive (F:) : N/A @ HL-DT-ST DVD+/-RW GU90N (SATA150, DVD+-RW, CD-RW)
Storage System
Storage Pool : Primordial (931.52GB)
Peripherals
LPC Hub Controller : Dell ICH80 (Lynx Point) LPC Controller
Audio Device : Dell ICH80 (Lynx Point) HD Audio Controller
Audio Codec : Realtek Semi 0292
Parallel Port(s) : 1
Disk Controller : Dell ICH80 (Lynx Point) 6-Port SATA AHCI Controller
Disk Controller : Dell SD/MMC Card Reader Controller
USB Controller : Dell ICH80 (Lynx Point) USB3 xHCI Host Controller
USB Controller : Dell ICH80 (Lynx Point) USB2 Enhanced Host Controller #2
USB Controller : Dell ICH80 (Lynx Point) USB2 Enhanced Host Controller #1
SMBus/i2c Controller : Intel ICH SMBus
Printers and Faxes
Printer : Send to Microsoft OneNote 15 Driver (1200x1200, Colour)
Printer : Microsoft Software Printer Driver (300x300, Colour)
Printer : Microsoft XPS Document Writer v4 (600x600, Colour)
Printer : Microsoft Print To PDF (600x600, Colour)
Printer : AnyDesk v4 Printer Driver (600x600, Colour)
Biometrics
Voice : Analog NUI Voice Virtual Sensor (Voice)
Network Services
Network Adapter : Bluetooth Device (Personal Area Network) (Ethernet)
Network Adapter : Intel(R) Ethernet Connection I217-LM (Ethernet)
Wireless Adapter : Dell Wireless 1550 802.11ac (Wifi4 (802.11n/HT), AES-CCMP, 111Mbps / 78Mbps)
Battery : LGC-LGC3.0 DELL 49VTP 56.16Wh/4.51Ah
Operating System
Windows System : Microsoft Windows 10 Professional 10.0.19043
Old 09-02-2022, 02:56 PM
smurfyou smurfyou is offline
Default Re: unable to link to file due to missing code
Is there a reason you're using a legacy SD codec? Has it worked in the past with this same method? Does it play in Quicktime? Have you tried another legacy codec like DVCPro or Prores?
Unfortunately that error message doesn't always mean the codec is the actual problem. Could be a filename, could be an error in the file.
~Will
Old 09-02-2022, 04:21 PM
The Weed's Avatar
The Weed The Weed is offline
Transcode the file to different codecs until one works with the free www.shutterencoder.com.
If the video will come in, but not the audio, bring in the video without the audio, use Shutter Encoder to strip off the audio and import that wave file.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 09-21-2022, 06:08 AM
it was working perfectly fine earlier sir...
just thought of upgrading laptop so along with hdd ive msata now.
VIDEO ISSUE - Unable to link due to missing CODEC or unsupported file AlessandroSaini Pro Tools 12 9 09-01-2022 01:13 PM
Unable to link to file "filename.mov" due to either a missing CODEC or the file may b iamb Pro Tools 12 1 09-28-2017 06:44 AM
"Unable to Link to file" Sound B Post - Surround - Video 3 01-31-2016 11:55 PM
Video codec for Black Magic Deck Link actualsizeaudio Post - Surround - Video 23 07-12-2013 06:26 PM
Missing codec helloo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-07-2006 05:23 AM
