adding hardware delay after the fact
Greetings. I've got three stereo tracks that are already recorded and I wish to add digital delay to the tracks by means of an external Lexicon hardware device. I've been trying to intuit my way through this all morning, but it's too much for my limited brain cells. How would I best route things to add this hardware delay to the existing stereo tracks? thanks a lot.
Re: adding hardware delay after the fact
Flyer,
You didn't mention what "box" you are using. I use a 001. Too bad you haven't heard from someone who actually might have done this because I would like to know the best way too... but here goes a guess... I'm a guitar guy so I have a pod pro here at the studio. I have had success running dry tracks out to the pod and back into PT thru the spdif ins and outs. You didn't mention if your Lexicon has spidif but if it does you might try running a dry track out spidif to your lex then back into "a new track". Just record enable a new track and input the spidif output from your lex. Then you can color it any way you want but it will be "printed" to disc. Then mute your original tracks to hear the difference etc... I don't really know for sure - just noticed nobody answered you for a while and I'm trying to help. I'll try this sometime myself to see how it might work. Good luck Mike |
Thanks for replying, Mike. I do have an 001. My problem is further complicated by the fact that I basically bypass the blue box, using a Rosetta to go in optically, and a DAC1 to go out, via s/pdif. So the ins and outs are too complicated for me to figure out. Trying to use the Lexicon, which doesn't have s/pdif's, caused my session to crash and it made all my audio playback too fast, as it was apparantly clocking to the Lexicon. I've given up, and will probably re-record the parts, using a digital delay pedal to actually record the parts going in. thanks again.
Manually Adding Delay to FX Sends? | conleec | Post - Surround - Video | 2 | 09-27-2013 11:44 AM |
So does LE in fact have delay compensation? | digidesigner | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-17-2010 03:50 PM |
Delay and crackle when adding or removing a plugin | Mattafact | Pro Tools TDM Systems (Win) | 11 | 03-24-2009 02:30 PM |
adding delay to tracks from tape | Brain Digger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 06-19-2004 05:34 AM |
Adding External Effects After the Fact with MBox | surefootedllama | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 10-29-2003 07:58 PM |
