Old 10-22-2022, 01:37 PM
jeffpardo jeffpardo is offline
Default New MacBook Pro/ Old OS
Hey all - I’m in the market for a 14 inch 2021 M1Max MacBook Pro, but today, found out anything ordered will ship with Ventura instead of Monterey as it releases on Monday. This, of course, sucks for software compatability.
Is it true that if a computer ships from Apple with Ventura, there’s no way to go backward in OS to Monterey?
If so, I could wait for the M2 Max MacBook Pro, but these M2 heat issues make me nervous!!
Thoughts???
Thank you!!!
Old 10-22-2022, 03:04 PM
off the wall's Avatar
off the wall off the wall is offline
Default Re: New MacBook Pro/ Old OS
Thoughts???
Thank you!!!
The 14” MBP you buy after Monday will likely be able to run Monterey. Only new Apple hardware designed and initially released after a new OS, will be incapable of running an older macOS.
A future hypothetical M2 Max MBP would certainly not be able to run a macOS released before the hardware release.
offthewallproductions
Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.9.8, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.4
Pro Tools Ultimate 2024.3.1/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface.
Genelec 1031AP/7070A 5.1 monitoring.
Old 10-22-2022, 03:29 PM
JFreak's Avatar
JFreak JFreak is offline
Downgrading a Mac to the OS it originally shipped with (on launch day, not your order day) is possible, but lately been made tricky. Once you get your machine, googe these things before you go on with nthe downgrade
- apple t2 security chip
- apple security regarding OS reinstall
- how to boot from external drive on m1
- external drive requirements m1 external boot
You will need to do this research either before you start doing it or while doing it. OS up/downgrades are not so straight-forward they used to be.
Janne
Old 10-22-2022, 03:44 PM
audiobob's Avatar
audiobob audiobob is offline
Where did you hear this? It's my thought that they won't unbox all those laptops just to install Ventura. I'm pretty sure they'll be installed with Monterey....especially if you purchase from a 3rd party like B&H.
Old 10-22-2022, 03:48 PM
JFreak's Avatar
It is just up to what has been sent from factory
Janne
Old 10-22-2022, 05:13 PM
The apple website said Ventura as OS, which I confirmed with an Apple tech person. B/c it’s a custom order (not an in stock machine), likely will have Ventura.
Any thoughts on M2 stuff?
Regular Macbook Pro vs. Macbook Pro with Retina display pzykt macOS 9 04-02-2013 08:32 AM
Experiences running Eleven Rack with a USB3 MacBook Pro or MacBook Pro Retina? Darryl Ramm Eleven Rack 3 09-18-2012 11:22 PM
Request advice on PTLE Macbook vs Macbook Pro mtbass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 03-08-2007 08:53 AM
macbook/macbook pro buffer problems, solution therecordinghouse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-21-2006 04:07 PM
Davecs for Macbook or Macbook Pro running Windows? sgladm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 06-16-2006 08:03 AM
