Strangest Behaviour!
Hello there,
I'm a relative novice with Pro Tools 10 and I've used it pretty much fine for a few months now except i ran into a very perplexing problem which is really starting to annoy me and make working utterly impossible. Whenever I change the grid value on the transport bar (eg. 1/16, 1/4 etc) it seems to change MIDI playback speed, but ONLY MIDI! At 1/16 everything plays at normal speed, at 1/8 everything is double timed, at 1/4 tripled, at 1/32 it is halved.... what on earth is going on?? The song audio plays fine it's just midi! And thats not all... it also accordingly shifts all the midi to the right or left depending on if you change the grid value up or down! Ever since this started happening i've also noticed that when i rewire into reason, anything I put into the reason sequencer seems to just move around at random, often by several bars at a time...MADDENING! I uninstalled Pro Tools (i had to install the 10.3.4 update anyway) and it hasn't changed it....what should I do? Thanks very much! |
Re: Strangest Behaviour!
This is how it should work.... Midi is following that tempo grid... when you change the grid you move the midi notes.... It has always worked that way. I do believe you can switch the midi to ticks or something similar and it will not move with the grid or maybe it is changing from ticks to samples... can't remember, I do know that changing the audio tracks from samples to ticks will allow you to change the audio clip tempo.. someone who deals more heavily with Midi in Pro Tools could probably tell you exactly how to do that.
As far as reason moving notes around do you have auto input quantization on your Midi input?? If so this may be automatically shifting your midi notes based on what setting your set input quantize to... If you think this is a bug or session corruption then try trashing your preferences and if that doesnt work, then Open a new session and import session data from the session your currently using. Prefs... http://www.youtube.com/watch?v=Mj2fJHOz8GA Import session data... http://www.youtube.com/watch?v=zeNj9TxKIlo
-Systems Engineer, Systems and Sound Designer, Recording and Mixing Engineer Last edited by jasonthurley; 04-23-2013 at 04:15 PM. |
Input Quantize Command When Input Quantize is enabled in the Event Operations window, all recorded MIDI notes are quantized automatically. To enable Input Quantize: 1 Choose Event > Event Operations > Input Quantize. 2 In the Input Quantize page, select Enable Input Quantize. 3 Configure the other options in the Input Quantize page. (For more information on the Quantize options, see “Quantize Command” on page 892.) 4 When finished, close the Event Operations window. There is an application made for trashing pro tools preferences... just google search for it ( pro tools preference trasher)and it should show up.
-Systems Engineer, Systems and Sound Designer, Recording and Mixing Engineer |
Strangest error message | sass | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-06-2007 04:47 AM |
002r, Firewire and the strangest day ever.. | Michael Carpenter | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 08-29-2006 08:01 AM |
Strangest with Midi Aux Tracks & Sythns | Alexycon | MIDI | 1 | 06-25-2005 06:56 PM |
OT: Strangest Request for Sound FX . . . EVER | rockrev | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-06-2004 06:07 PM |
yes...OT...Strangest Session Moments... | lemix | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 29 | 06-29-2004 04:23 AM |
