Old 11-27-2011, 01:54 PM
RoxyRiot RoxyRiot is offline
Default Alesis Desk through Pro Tools
I'm trying to run an Alesis Multimix 12USB desk into Pro Tools 9 and for some reason, Pro Tools won't pick up the desk as an input. It uses the desk as an output for sound, but won't pick any levels up when recording in.
Does anybody know how to configure this? I'm using Windows 7.
Thanks.
Old 11-27-2011, 01:57 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Alesis Desk through Pro Tools
Thanks.
Have you gone to the hardware setup page and assigned the inputs for your interface? Would be something like analogue 1/2 etc. then in pro tools those inputs should show in the inputs menu.
Chris
Producer, Engineer,
www.ukmastering.com
Old 11-27-2011, 02:09 PM
Hmmm, when I go into hardware setup, I only get an option of the ASIO drivers I installed earlier on (asiosforall). When I click on there, it doesn't let me do anything really - just tells me that Pro Tools needs to restart to configure the changes :/
Old 11-27-2011, 02:20 PM
crizdee's Avatar
You are in the playback engine settings!! That's where you set the Asio driver! Asioforall is basic and could be part of your problem, is there not an Alesis driver available?
The outputs need to be assigned in the Hardware setup page, which is a different page from the playback engine page.
Chris
Producer, Engineer,
www.ukmastering.com
Old 11-27-2011, 02:38 PM
I've opened the Hardware setup page and it now says that the USB connection is active, but I still can't seem to find it when looking at a channel's I/O settings - I'm still getting the same problem It still says it is going through the computer rather than the desk!
I've emailed Alesis about any missing drivers as they have none on their website for my desk for some reason.
[IMG] code is Off
Getting Pro Tools to ignore 'Desk Nudges'? Soundburst macOS 2 11-28-2012 02:01 AM
002 desk completely compatible with pro tools 9? nemesphyxia Pro Tools 9 2 03-29-2011 04:58 AM
PRO Tools le 8 m box micro and 002 desk stevier 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-22-2010 04:27 AM
Controlling an automated analog desk via MIDI from Pro Tools barish MIDI 4 03-13-2007 11:59 AM
Is a big desk necessary with Pro Tools? dhn General Discussion 11 06-23-2000 09:44 AM
