Go Back   Avid Pro Audio Community > Other Products > The Drum Room
Old 11-29-2009, 08:29 PM
56BelAir 56BelAir is offline
Default bfd lite vs bfd pro
Can someone explain to me some functions/features that are different between BFD Lite and 2? I know the library is bigger. I'm currently recording with BFD Lite for drums sounds only using the Roland PD-7 pads. I don't intend to use any electric cymbals or auxiliary percussion.
I'm interested in knowing what additional editing, sub-mixing, and/or tone control (to name a few) BFD2 is capable of.
I'm actually content with the default drum set that's in BFD-Lite. The Master, Overhead, Room, and trim controls seem to be adequate if you like the drum that is being triggered. So I need someone to twist my arm and let me know why I should go to BFD2.
Paul
Parker, CO
Old 11-29-2009, 08:40 PM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Default Re: bfd lite vs bfd pro
The Drum library(s) alone is enuf but multiple outputs, processing within the plug...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 11-29-2009, 09:09 PM
The samples in the full version are much higher detail with additional articulations and positions - especially on the Hihats.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 11-30-2009, 04:40 PM
Nobody is twisting my arm? Come on people, give me some more feedback!
Paul
Parker, CO
Old 11-30-2009, 05:02 PM
77pro 77pro is offline
Paul
Parker, CO
Go to the fxpansion website and check out bfd2. If it's got some additional features you like, then upgrade.....no arm-twisting necessary.
003r/i7-930/LE 8.0.1 cs2 on xp
Old 11-30-2009, 05:11 PM
Rite & not to mention the below quoted statements
Rail
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
Old 11-30-2009, 06:21 PM
nst7 nst7 is offline
You can actually download a limited demo of BFD 2 and check it out. It's standalone and you can't use it in any DAW and only has one kit, but it gives you an idea of how the mixer and other features work. It won't affect your BFD lite.
BFD Lite in 8.0.4 Darryn Farrugia 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-18-2011 11:14 PM
BDF Lite seems EXTEMELY lite manis Virtual Instruments 11 07-23-2009 05:59 AM
Digi Live Lite 6 and M-Audio Live Lite 6 PRS4LIFE 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-19-2007 03:52 AM
bfd lite help... thevital 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 12-27-2006 12:08 AM
BFD Lite RTPro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-24-2006 07:30 AM
