Old 09-17-2017, 02:47 PM
willl3 willl3 is offline
Default right click select whole clip when trying to cut it
I know I can just press b but my work flow
is point to the area in the clip right click and cut
when I right click it selects the whole clip
grrrrr I know its something I'm missing and it simple just can get it and its frustrating
win10 prot 12.8
windows7 HP XW8400 Workstation Xeon Dual-Core 5150 2.66GHz 12gig ram
Old 09-17-2017, 07:13 PM
Default Re: right click select whole clip when trying to cut it
Just my 2 cents; you're doing it the hard way instead of the easy way(drop the cursor and hit B is about the easiest edit done in PT)
Old 09-18-2017, 02:53 AM
Default Re: right click selects whole clip when trying to cut it
it requires me to move my hand off the mouse or use my other hand (holding instrument)
I don't know why when I right click it selects wht whole clip. It must be in options or something I cant find it but it change after upgrading from 12 to 12.8
help!
I drop the cursor right click then cut..... i just want to do that...
anyone?
Old 09-18-2017, 04:04 AM
joachim's Avatar
joachim joachim is offline
You could try right-clicking and then "separate".
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 ,
Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060
Old 09-18-2017, 06:09 AM
amagras amagras is offline
Make sure you have activated and know how to use the smart selection tool.
amagrasmusic.com
Old 09-18-2017, 09:32 AM
Maybe its time for a mouse/trackball with some extra buttons?
Old 09-18-2017, 12:40 PM
YYR123's Avatar
YYR123 YYR123 is offline
yes same here.....He should disable the multi tool. Just leaving the cursor active. imho
Daniel
Old 09-21-2017, 06:09 PM
If I could do that then I wouldn't have to post this
when cursor is on the cut
I right click
separate is grayed out
and the whole clips gets selected
I don't get a chance to use separate in the pull down
I'm missing something to uncheck in the prefs or the tools
Old 09-22-2017, 04:39 AM
I right click
Do you have the track selected (the name is highlighted)?
What instrument are you holding? There are times when I track guitar (I'm also playing) and when I stop I need to make edits. This is where having a strap on the guitar (and using it) is a necessity. I can let go of the guitar and do what I need to do in PT even using both hands if necessary. Only downside is banging the headstock into the desk every once in a while
If you're playing a sax get a neck strap. Now if you're trying to do an Ian Anderson thing you have to put the flute down.
Old 09-22-2017, 05:07 AM
joachim's Avatar
I right click
Could you clarify : do you then click at this position or are you going right away for a right-click ?
If you go on the position and click and then right-click, it should work.
If you go on the position and click , but move the cursor away from the vicinity of the position and then right-click, it cannot work.
Keyboard Shortcut to Select the Next Clip in Clip List TomMxEdit Pro Tools 12 1 02-27-2017 11:52 AM
select next clip in timeline (on all tracks) johannes1 Pro Tools 10 3 07-07-2015 09:48 AM
How do I select multiple regions in the clip list? Moviesound Post - Surround - Video 5 08-25-2012 05:31 AM
How select a clip with Artist Control? John Fishback Artist Series 4 05-21-2012 09:23 AM
grabber doesn´t select clip with fades Frank Kruse Post - Surround - Video 0 07-14-2005 08:44 AM
