Re: How many tracks in PT11 non-hd?
PT mixer can have as many tracks as you wish, but the concept of VOICEABLE tracks means how many can be played back at once.
After that it will tell you "Too many Tracks for the current Pro Tools configuration." So this is changing in 11? |
I might have to stand corrected, but coming from the TDM land the issue has really been around voices and not tracks.
Don't get me wrong... I'd LOVE more voices in non-HD as well... but for most of the work I do, the bigger bummer is taking a large session home from the studio to edit and having to break it 2 or more smaller sessions because I simply can't open the main session without pro tools dropping all the tracks after 128.
I guess we don't have an official word on this then. |
I don't know where you've got the 128 figure from ... it's "96 simultaneous audio tracks (mono or stereo)".
Here's the official PT10 comparison chart ... http://www.avid.com/US/products/Pro-...atures#Compare ... and the preliminary PT11 version, which I saw via a link in another thread but can't track down at the moment ... said the same. So if you were really desperate, it appears you could merge some mono tracks into stereo and have upto 192 'tracks' of mono data playing back on 96 stereo tracks. Assuming your system can cope with that. I'm also assuming that for any genuinely mono tracks that you've merged in this way to keep to the 96 limit, you could set each such stereo track's output to a stereo bus, and create a pair of mono aux inputs, whose inputs would be the L or R mono elements of the stereo bus. That way, you'll have separated them back to mono 'tracks' and can treat them with FX separately. Bear in mind though, that if you do too much of this, you'll then hit the 128 aux input limit in plain PT. It is a way to get more more than 96 mono tracks playing back though, if you're desperate enough to make the effort. |
I'm talking about how many tracks I can have in a session, regardless of whether or not they can play back. |
Sorry, I obviously should have paid more attention to what you said.
Sorry I don't have the answer, but it seems like somewhat of an unreasonable expectation.
Save early and often! (or once a day whether you need to or not...) |
Anyways, been dealing with this issue for years now, so I'll continue to deal, but it would be a huge plus if this was changed in 11. |
MacMini OS x 10.14.6 Core i5 2.5 GHz 16GB Eleven Rack |
11R won't stop monitoring in PT11, armed tracks or not. | ecalcagnino | Eleven Rack | 16 | 06-08-2014 05:57 PM |
PT11 to PT11 HD Native upgrade without hardware? | kirkbross | Pro Tools 11 | 2 | 11-04-2013 03:10 PM |
Monitoring non-record tracks through PT11 - am I going crazy? | yeloop | Pro Tools 11 | 2 | 07-22-2013 10:06 PM |
PT11 and PT11 HD differences | Fooks | Pro Tools 11 | 4 | 04-10-2013 12:20 PM |
Will HDX not compatible with PT11? or not the best for Pt11? | Rockman413 | Pro Tools TDM Systems (Mac) | 5 | 10-26-2011 10:00 PM |
