Pops, Clicks prob in 48kHz sessions - OK with 44,1
I have some kind of setup issue, but it's not obvious to me what to do to next address this problem. I changed my setup a month or so ago and am using Focusrite Clarett 2pre as my interface via Thunderbolt. I have been recording 44.1 sessions with no problems, and now trying to open and create 48kHz sessions.
The 48kHz session will open and play or record, but with constant cracks and pops. That sounds like a definite clock problem. I have changed the clock in Focusrite Control to 48 and the "sync" light is green. I have changed the session to 48 in PT. What am I missing? |
Re: Pops, Clicks prob in 48kHz sessions - OK with 44,1
I have previosuly used a Focurite Scarlett for additional input, and when doing that I set Focusrite clock to "ADAT" for the Scarlett channels, but now I am only using the Clarett and have Focusrite clock is set to "internal".
System details: iMac (Retina 5K, 27-inch, Late 2015 OSX El Capitan) 3.2 GHz Intel Core i5 16 GB 1867 MHz DDR3AMD Graphics Radeon R9 M380 2048 MB INTERFACE/PRE Focusrite Clarett 2Pre Interface |
I'm not a big Mac guy, so hopefully someone else will chip in here, but have you gone through the Optimization Guide? Are you using the latest Focusrite Control?
Joel
Jam Space: HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Home: Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626 Rig: Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM |
Thanks Joel...UI have done the Optimization. Found this on Focusrite website, and this is my computer and build so, just my luck...I'll keep working on it.
Applies to: Clarett Range |
Well that's bad luck! Hopefully their beta driver can get you going though, I've been using the beta driver for my Focusrite Scarlett 18i20 for almost a year now, seems to work well.
Joel
From Focusrite....
We have a beta build of our Thunderbolt driver which we believe alleviates the problem with glitchy audio present on playback at all sample rates using iMac 17,1 systems which you can download here: https://sync.focusrite.com/s/vWreI90Vs7PUVm7 |
For the archives... this has not solved my problems and I have emailed Focusrite. The clicks, when they occur, happen in both the Clarett and the Scarlett and get the clicks in the same spots...
Here is a session screenshot of a pop. There are 2 mics...one in Clarett 2Pre and the other in theScarlett 18i/20. "Life gets teejus, don't it?" Walter Brennan |
Do you have 2 devices connected by a digital connection(SPDIF or Lightpipe)? If yes, then its most likely a clocking issue as this requires one unit to be the master and the other must be the slave. and both need to be set to the same sample rate(look for an External Sync LED on the slave unit to show that its properly locked)
Just saw this...No I have the Clarett2Pre as a slave to the Scarlett's time clock via ADAT optical...and the sync lock is on. This is a know (but as yet unsolved) problem
Follow this work around, I'm on OS SIerra 10.12.2 and problem persists
https://www.logicprohelp.com/forum/v...656112#p656112 |
Mbox 2 Clicks and Pops ONLY IN 48kHz | ericwegener | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-08-2011 08:54 AM |
Pro Tools 8 Upgrade - Pops and clicks when opening 96k sessions | windstead | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-02-2009 11:52 AM |
mystery clicks/pops upon revisiting sessions | tokyofan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-29-2007 07:09 AM |
Pops and clicks on heavy sessions | stevesound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-22-2007 11:28 AM |
ENOUGH pops N clicks in sessions already! | studiojimi | Pro Tools TDM Systems (Mac) | 6 | 07-07-2005 08:39 AM |
