Re: feature transfer error during install
John Pro Tools 12.5 Macbook Pro & Windows 7 Ultimate 64 Bit |
The install disk is a "DUAL LAYER" disk....make sure your DVD player is compatible with this.
I may be wrong, but aren't all DVD burners compatible with commercial DL disks.? Most DVD movies are DL as well. IDK I'm currious.
Hello,
I just purchased the Digidesign 003+ Audio Interface Factory Bundle [Pro Tools 8.0] I am having the same Error: feature: documentation component: documentation Protools file: D:\PROTOO~6\data2.cab error: data error(cyclic redundancy check) I have tried all other options that have been suggested on this forum for this issue: 1. Copied over all files on the DVD to the hard drive (my desktop) & tried to run the installation from there - same error occurred 2. I checked to ensure the Firmware of my hard drive was up to date 3. I ran the Check Disk (chkdsk) function for the hard drive to ensure there were no errors Nothing has help / fixed the issues. Please Pro Tools / Avid Support - I'm getting really frustrated can you please help me with this issue - I really need to have this up & running this weekend for work. I've seen a possible solution is you can give me the download for both PRO Tools LE 8.0 & the Factory settings that came with my bundle. - If this is my only solution please assist. Here is the Case Number [#01219551] I opened for this issue. Here is my Sandra Report: SiSoftware Sandra Computer Model : System manufacturer P5QL-E Workgroup : MSHOME Host Name : ryansstudiocomp User : Ryan Morgan Processor Model : Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz Speed : 2.4GHz Cores per Processor : 4 Unit(s) Threads per Core : 1 Unit(s) Type : Quad-Core Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 On-board Cache : 2x 4MB, ECC, Synchronous, ATC, 16-way, 64 byte line size, 2 threads sharing Computer Mainboard : Asus P5QL-E BIOS : AMI 0401 06/03/2008 Bus(es) : ISA X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes Total Memory : 3.25GB DIMM DDR2 DDR3 Chipset Model : ASUS P45/P43/G45/G43 DRAM Controller Front Side Bus Speed : 4x 267MHz (1GHz) Total Memory : 4GB DIMM DDR2 DDR3 Memory Bus Speed : 2x 401MHz (802MHz) Memory Module(s) Memory Module : Patriot Memory 8500EL Series 1GB DIMM DDR2 PC2-8500U DDR2-1066 (5-5-5-16 3-21-6-3) Memory Module : Patriot Memory 8500EL Series 1GB DIMM DDR2 PC2-8500U DDR2-1066 (5-5-5-16 3-21-6-3) Memory Module : Patriot Memory 8500EL Series 1GB DIMM DDR2 PC2-8500U DDR2-1066 (5-5-5-16 3-21-6-3) Memory Module : Patriot Memory 8500EL Series 1GB DIMM DDR2 PC2-8500U DDR2-1066 (5-5-5-16 3-21-6-3) Video System Video Adapter : NVIDIA GeForce 7100 GS (4 PS3.0, 3 VS3.0 351MHz, 128MB DDR3 2x531MHz, PCIe 1.00 x16) Graphics Processor Storage Devices Seagate ST3160815AS (160GB, SATA150, 3.5", NCQ, 8MB Cache) : 149GB (C:) Seagate ST3750330AS (750.2GB, SATA150, 3.5", 7200rpm, NCQ) : 699GB (F:) Seagate ST3160815AS (999.5GB, USB/SATA150, 3.5", NCQ, 8MB Cache) : 931GB (I:) Seagate ST3160815AS (500.1GB, USB/SATA150, 3.5", NCQ, 8MB Cache) : 466GB (H:) TSSTcorp CDDVDW SH-S203N (SATA150, DVD+-RW, CD-RW, 2MB Cache) : 8GB (D:) TSSTcorp CDDVDW SH-S203N (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (E:) WD Virtual CD 1110 (USB) : 668MB (G:) Logical Storage Devices Hard Disk (C:) : 149GB (NTFS) @ Seagate ST3160815AS (160GB, SATA150, 3.5", NCQ, 8MB Cache) Audio Drive (F:) : 699GB (NTFS) @ Seagate ST3750330AS (750.2GB, SATA150, 3.5", 7200rpm, NCQ) Pro Tools LE (D:) : 8GB (CDFS) @ TSSTcorp CDDVDW SH-S203N (SATA150, DVD+-RW, CD-RW, 2MB Cache) Optical Drive (E:) : N/A @ TSSTcorp CDDVDW SH-S203N (SATA150, DVD+-RW, CD-RW, 2MB Cache) 3.5" 1.44MB (A:) : N/A WD SmartWare (G:) : 644MB (UDF) @ WD Virtual CD 1110 (USB) My Book (I:) : 931GB (NTFS) @ Seagate ST3160815AS (999.5GB, USB/SATA150, 3.5", NCQ, 8MB Cache) BLACK BOOK (H:) : 466GB (FAT32) @ Seagate ST3160815AS (500.1GB, USB/SATA150, 3.5", NCQ, 8MB Cache) Peripherals LPC Hub Controller 1 : ASUS LPC Interface Controller LPC Legacy Controller 1 : T0 A5-13 Audio Device : ASUS HD Audio Controller Audio Codec : Realtek Semiconductor 888 High Definition Audio Serial Port(s) : 1 Disk Controller : ASUS 4 port SATA IDE Controller Disk Controller : ASUS 2 port SATA IDE Controller Disk Controller : ASUS JMB36X PCIE-to-SATAII/IDE RAID Controller USB Controller 1 : ASUS USB UHCI Controller #4 USB Controller 2 : ASUS USB UHCI Controller #5 USB Controller 3 : ASUS USB UHCI Controller #6 USB Controller 4 : ASUS USB EHCI Controller #2 USB Controller 5 : ASUS USB UHCI Controller #1 USB Controller 6 : ASUS USB UHCI Controller #2 USB Controller 7 : ASUS USB UHCI Controller #3 USB Controller 8 : ASUS USB EHCI Controller #1 FireWire/1394 Controller 1 : ASUS IEEE 1394a Firewire Controller SMBus/i2c Controller 1 : Intel 801xx/63xx SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Printer : Microsoft Office Document Image Writer Driver (200x200) Printer : Canon MP160 Printer (USB, Colour) Printer : Adobe PDF Converter (4000x4000, Colour) Network Services Network Adapter : Atheros AR8121/AR8113/AR8114 PCI-E Ethernet Controller - Packet Scheduler Miniport (Ethernet, 1Gbps) Power Management Mains (AC) Line Status : On-Line Operating System Windows System : Microsoft Windows XP Home 5.01.2600 (Service Pack 3) Platform Compliance : x86 Thanks for the help! Ryma |
Is there anyone that can help on this? or give me some direction?
It would be much appreciated. Thanks. |
#16
Feature transfer error | criemann | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-11-2011 10:22 AM |
Feature transfer error | criemann | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-11-2011 10:17 AM |
Trouble installing Pro Tools (Feature Transfer Error??) | sorenfgp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-24-2010 10:36 AM |
Feature Transfer Error... HELP!!! | Funkle | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-15-2010 06:35 PM |
Feature transfer error 7.3 | filosofem | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-06-2006 06:45 PM |
