> Help with my confusing live PT setup
My band records at home with PT and an MBox. We're a pretty interesting mix of sounds, but feature relatvely heavy guitars along with a good amount of electronics, etc.
ANYWAY... when we play live I have a session running with one stereo track with all the sequenced material, and another track with Reason coming through ReWire. I play Reason live with my usb midi controller. So basically I have to bring my MBox to shows to have it sitting on top if the rack (because of its awkward shape and size), and all that... I'm just looking for a better, less-likely-to-crash kind of setup. Something a little less complicated maybe. Anyone? |
Re: > Help with my confusing live PT setup
You would net an amazing increase in versatility if you upgrade to a DIGI002(or the rack version). Wouldn't it be nice to have instruments on seperate tracks for mixing? Plus the 002R mounts very neatly in a standard rack.
Hmmmm, not quite sure what you're asking. Are you suggesting your set-up is crashing, or just that you're worried about it crashing? If you want to play Reason live, then you're going to need some kind of audio interface (unless you simply use the internal audio interface of your Power/iBook) and the Mbox isn't really much different in size and shape from others.
Perhaps the most solid set-up would be to have the backing on minidisc and play a hardware synth, but this may not give you the sounds/interactivity you want. It sounds, to me, like you have a fairly simple set-up. A 002R with multiple outputs certainly won't be any simpler. You could always fine a way of mounting your gear in a case, with everything connected and ready to go? |
Best Live Setup?? | tdblanchard | Eleven Rack | 1 | 01-08-2014 02:16 PM |
11R with JCM 900 live setup help | Gatekeeper666 | Eleven Rack | 8 | 11-03-2011 01:10 AM |
need help with live setup | ilulilu888 | Pro Tools TDM Systems (Mac) | 1 | 01-05-2010 07:04 AM |
advice for live setup | ilulilu888 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-07-2009 07:24 PM |
Digi confusing an already confusing issue.. | DMK | Post - Surround - Video | 4 | 01-26-2009 03:18 PM |
