Symphony I/O with HD Native - lots of relay clicking
Hoping to shed some light on a couple questions.
Been using a Symphony I/O 24 I/O with one of the Accel rigs and it's been very stable. Switching between PT and Stand-alone modes creates relay clicking, as I'm sure you guys have heard before. Just started using the same Symphony I/O with an HD Native setup on the trashcan Mac Pro, but I have some concerns. After some in-house testing we ran it for a couple live sessions and we were getting relay clicks quite often. About 6 during the loading of PT. Clicks sometimes when adding plugins, clicks sometimes when adding tracks and things like that. Also two freezes during the session. We had a PCIe HD Native card in a Thunderbolt Magma chassis. Figuring it was something to do with that we got a HD Native Thunderbolt instead. Same relay clicks quite regularly, but haven't had any freezes yet (knocking on wood). Are you guys using Symphony I/O (not the black one with the tiny display) hearing quite a few relay clicks while using yours? This exact same Symphony I/O has been flawless with Accel, so I don't think there's an issue with it, but maybe this is just part of the territory with HDN and Symph I/O. Any experience would be appreciated. |
Re: Symphony I/O with HD Native - lots of relay clicking
unfortunately symphony is not very useful with hd native.. when your cpu load gets close to 100% or even when it spikes on smaller sessions it can trigger a relay click, dropout of audio etc. whereas any other interface would just keep going.. the MK1's only really work well with HDX or TDM... I found it works great natively with a pcie64 card (no clicking natively under same conditions) but you lose the hd card benefits obviously.. you would find with a hdx card it is very useable.
System Details |
Mine's connected to an HD Native PCI card in a machine room.
I'll do some tests tomorrow, but I think I only get relays switching when changing sample rate. Will check. |
Hi, the same here.
I've been working almost 3 years with Symphony I/O MkI on USB mode, and 2 months ago I've added HD Native PCIe - ...yes...hearing these relay clicks annoys me too. But I found something about it from apogee: http://www.apogeedigital.com/pdf/Sym...structions.pdf I suppose it's normal behaviour ... |
Thanks for the responses!
Are you guys ever experiencing system or PT hangs? |
So do the clicks change behavior?
Does it impede recording ? Does it cause PT to hang? I have found a good deal on one of these mk1 units and i want to use it as a 2nd io for my HD|N
No system or PT hangs. It's stable , but ... these clicks ...
I found that it's much better when Maestro is closed when using PT. |
I assume they can update the firmware to change this right?
How is Apogee’s service and support ?
Just did some tests.
I only get relay clicking when launching PT, quitting PT, or opening sessions with different sample rate. No clicking when inserting plugs or making tracks. |
Used to be awesome. Now they don't have phone support, but it's still okay. |
Apogee Symphony 64 w/ Pro Tools Native HD | clancychris | Pro Tools HDX & HD Native Systems (Mac) | 6 | 10-26-2017 01:12 PM |
HD Native With Apoggee Symphony | jaminjamesp | macOS | 8 | 02-09-2016 12:58 PM |
Pro Tools HD Native & Apogee Symphony IO errors | Chris Coulter | Pro Tools 12 | 3 | 09-07-2015 07:32 AM |
hd native + apogee symphony? | ericlees | Pro Tools HDX & HD Native Systems (Mac) | 12 | 01-23-2013 03:38 PM |
HD Native/omni vs Apogee symphony | Matchless Gift | Pro Tools HDX & HD Native Systems (Mac) | 10 | 04-16-2011 07:41 AM |
